pink/white noise generator
- aaronlyon
DP used to have a plug in for setting up your monitoring speakers. It could generate noise. I thought it was the Trim plug, but no. I need white noise. Any suggestions?
DP7*, Mac Pro Quad 2.66GHz, 12GB RAM, MOTU 828mk3, Mac OS 10.6*
* Bleeding edge updater--if it's released, I've updated, and bled.
Re: pink/white noise generator
I use AudioTest by Katsura Shareware. It generates all kinds of files and is very useful, I find.
Kubi
Kubilay Uner
http://kubilayuner.com
Kubilay Uner
Check out the MeldaProductions stuff. Freeware. Good tools.
DP 8.07 64 bit, OS 10.10.5, Mac Pro 5,1 12-core 3.33ghz, 16GB ram, lots 'o plugs and VIs
+1 on AudioTest. I've had it for years, and use it much more than I thought I would. It let's you save as an audio file, or it will just run it. It does let you control the levels (for ear safety) but don't forget to.
It has lots of wave shapes, and different flavors of noise (including the South Park favorite, brown).
DP still has the plugin you want. It's called "Calibration", a MAS plugin.
It only generates pink noise though, not white.. I'm assuming you need white (burst) because you need to calculate the reverb in your room?
