Trim vs Meter Bridge
crankygnomes
Post by crankygnomes »
On DP 7.2, why is the level of a given recorded track much different according to the Trim plugin as opposed to the Meter Bridge?
Phil O
Re: Trim vs Meter Bridge
Post by Phil O »
Well, if your trim plug is pre-fader and you have "Tracks" selected in Meter Bridge (which is post-fader) the difference will be the fader setting. On my system, if the fader is set to zero, a trim plug insert reads identical to the meter bridge reading.
crankygnomes
Thanks for your patience.
