All Busses are present but not working??
donreynolds
Post by donreynolds »
I have a project that was working great last night. Left the project up and went to work on it this morning and found a note that my primary hard drive was full. and computer was locked.
I had my project on an external drive. I restarted my computer and deleted a crap load of old files from the primary and freed up about 90 GB.
I reopened the project and now none of my busses are passing audio.
If I reset the tracks to my main outs everything is there and audible, but when I resect outputs to busses, the audio is not present in the received group track, indicated by meters .
Example. All drum tracks or rhythm guitars going to a single stereo group track. Indicators no audible audio.
I have repaired permissions, restarted, reopened project several times but no change.
Any suggestions?
I check my bundles window and everything appears to be ok there also.
Mac Studio M2 OS 15.3 Sequioa, Presonus Faderport 8, 150gig Raptor x 2, Glyph 2Tb drive DP 11.33, Antelope Discrete 8, BLA microclock ll, Presonus Central Station, Waves Plat. V7 , Slate Everything, Melodyne studio, SSD 5, TruePianos, Event 20/20 bas, Adam A7, Avantone Active MixCube, and other toys, Lotsa guitars, HeadRush GTR processor and a Korg Triton)
Phil O
Re: All Busses are present but not working??
Post by Phil O »
I don't know what's the deal is with busses. Every once in a great while I'll have a buss that won't pass audio. The fix seems to be to delete the bus and re-create it. No rhyme or reason to it. It's only happened to me maybe three or four times ever. But I have seen this. I have no idea what causes it.
donreynolds
I'll give it a try. small aggravation but if that fixes it, it will be cool. I keep a notebook of all my assigned busses as they can get confusing at times.
Thanks, Phil
I think there was a recent post where someone quit Safari and got the bus audio back. I know, crazy. I'll try to find that later.
donreynolds
I just deleted my busses and tried to recreate a few. The thing that I now notice is that the track sends work going to an aux track such as for verb ,etc. but if I use a bus to send from track output to the input of another trance does not work. I have input selected also on the receiving track as is supposed to do but still no go.
donreynolds
Re: All Busses are present but not working?? Solved!!
I found out what is happening is that my input button was not function correctly.
I opened a track and plugged a guitar and was not able to hear the audio but it was indicating on the audio monitor that it was coming in. I recorded a little and it is recording audio information and am able to play it back.
I checked my ado preferences in the studio and found that it had reset to input monitor through hardware. Reset to input through effects. Fixed it. Crazy.
Now I have to rebuild my bundles.
At least the project was not messed up.
Whew.
Thanks guys, sorry for the trouble.
Maybe that will help someone else later on?
