Ableton Live / MOTU Ultralite problem
noCore
Post by noCore »
I am experiencing an odd issue with my audio/MIDI routing.
My Ableton project is set up, working fine with multiple ins and outs through the MOTU, and MIDI as well.
When I restart my laptop, and open up the project again - Ableton no longer sees the MOTU - so I need to tell Ableton to use the MOTU - and re-select all my ins and outs.
Also - for any MIDI channels, I have to redirect the track to MOTU - but it no longer shows as "MOTU Ultralite" - instead it shows "MOTU Ultralite #2"
subsequent reboots experience the same thing, but each time the # goes up... "MOTU Ultralite #3, #4 etc.. ."
I am currently at "MOTU Ultralite #8" - wondering how long this is going to continue. Having to reset all my ins and outs and MIDI connections is a bit of a pain :-(
I didn't have this problem before (on a different MacBook Pro running Snow Leopard... with a straight Firewire400 cable.
So I'm not sure if this is an issue with Live... with MOTU (having to use a Firewire800>400 cable now with the new MacBook)...
Any thoughts or suggestions would be much appreciated.
Thank you for your time.
.miQ
www.creativefrequencies.com/nocore
jdmonteagudo
Re: Ableton Live / MOTU Ultralite problem
Post by jdmonteagudo »
Did you find out the solution for this issue??
I have the same problem, each time I restart the computer a new ultralite #2 MIDI device is created...so Ableton lose his configuration.
I've tried a lot of things, uninstall and reinstall drivers, reset factory defaults etc...
Thank you
Traum
Post by Traum »
Is this sorted now? What was the issue? Do you use it with Live 9?
vimanaboy
Post by vimanaboy »
I'm having this problem also! I was on UltraLite #54 when I discovered it. Deleted them all except one, but it keeps happening. I'm using Logic Pro X on OS 10.8.4, 2011 2.7gHz 27" iMac i5.
PS: I am using the original UltraLite Mk1 - how about you guys?
MOTU_Tech
Post by MOTU_Tech »
Hello!
This problem is addressed with our latest audio driver, available here:
http://www.motu.com/download
I encourage anyone who is still having problems to contact MOTU support directly.
Cheers,
MOTU Tech Support
Please advise all technical inquires should be submitted directly to MOTU's support channels (phone and online support).
