Anyone using the Behringer BCR 2000 for controlling Stylus RMX? I made the standard USB connection but the problem is, that anytime I quit and restart my DP project, the Behringer controls are all set to a default position and not to the actual values Stylus RMX is set, which I thing means that Stylus or Performer are not sending any messages to the Behringer...What can I do?
Tom
Behringer BCR 2000 and Stylus RMX
RMX/BCF 2000… please help
First, Are you successfully establishing communication ?
I have the same BCF 2000 + Stylus 1.5 and I'm not able to establish communication... how are you doing that ? I've watched the video tutorials and read the forums and still no luck.
The only successful operation I've managed has been to load v1.10 OS
as the machine came with 1.07 loaded, AND, by putting machine into
Baby HUI mode (with machine powered off... press/hold button #5, just below panpot/encoder 5 and then power the machine on) The lower right buttons are attached to the transport.
To get out of HUI simulation, power off, then hold button 1 and power on.
Many TIA
Many TIA
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
