DP 8.04 Set Movie Start Time Not Working
Title says it all.
Anyone else have this?
Claude
iMac i7 3.4 ghz
32 G Ram
Claude
iMac i7 3.4 ghz
32 G Ram
- Gravity Jim
Re: DP 8.04 Set Movie Start Time Not Working
Not a problem here, at least not with a QT .mov (I don't have any other video handy to check with). Set start time to 0:00:30:00 and it worked just like always.
Jim Bordner
Works here.
Thanks guys!
Weird it's like a GUI problem here. If i enter the numbers and press enter it works but i'm working blind. the GUI for that window is frozen and gives no interaction...
Claude
Claude
You might try using the consolidated window and then popping the movie in and out of it (ctl-1) to see if that resets it. It might also be a good idea to reinstall DP if that doesn't work.
There are a few threads that deal with specific graphic cards that are not working as well. I'm not sure which they were since I never had one of those cards.
What theme are you using for DP8? If you switch to a different theme do you have the same problem?claude wrote:Thanks guys!
Claude
Dave
Hi Dave,
i was using the default 8.0 Theme. Switched to Deluxe and a few others and it's still not working.
Claude
Claude
Can you send me a screen shot of what you see?claude wrote:Hi Dave,
Claude
magicd@motu.com
Dave
Thanks Dave,
done through my Gobbler service so check your spam folder if you don't see the link to my Screencast.
Thanks again!
Claude
Thanks again!
Claude
