UAD-2 v7 in 64-bit
- cwalcott
UAD-2 v7 in 64-bit
I tried searching for this topic but came up empty. I'm sure it's been discussed so if there's a thread to read, point me to it. thanks!
I'm running DP 8.01
mac os x 10.6.8
quad core 3,1
putting DP into 64 bit mode I can instantiate UAD plugins but they come up empty.
any ideas? do I need to upgrade to mt. lion?
- chris
I'm running DP 8.01
mac os x 10.6.8
quad core 3,1
- chris
Re: UAD-2 v7 in 64-bit
UAD-2 7 is working on 10.68 with my Mac, which is older than yours. They have worked with the DP 8.02 and DP 8.03 demos. My only quirk with UAD-2 ver. 6 & 7 has been with presets not remembering the name of the chosen preset when reopening a project. This also happened with DP 7.24.
Mac Pro 2x2.4 quad core /24 gb ram/OS 10.13.6, Dp 10.13, MTP AV, /UAD 2, KOMPLETE 12, Stylus RMX, SD 3.0, EZ Drummer 3, A&H ZED R 16.
- Gravity Jim
According to the website, when UA plugs went 64-bit, they required a 64-but kernel.
From the 6.4.1 release notes:
System Requirements:
• Mac OS X 10.7 Lion or 10.8 Mountain Lion is required
• Mac OS X 64-bit kernel mode is required
Jim Bordner
- cwalcott
64-bit kernal makes sense. i tried to boot into 64-bit mode in the os by holding down the 64 keys but for some reason it didn't work. i decided to go ahead and upgrade to mt. lion. i'm sure this will address the issue.
thanks!
- chris
thanks!
- chris
Actually, with the 6.5 release, Snow Leopard support was reinstated, and 64-bit operation when booted in 32-bit kernel was made possible. I don't think that's changed with v7 (although I haven't installed it yet).
Mac Studio Max M1 | 32GB | 15.3 | 828es | M4 | DP 10.13 | Studio One 7 | Logic 11
UAD-2 ver. 7 does work with 32 bit kernel and 64 bit app.
Thanks for reporting that, RROY -- good to know!
- cwalcott
well, i'm sad to say that UAD-2 is not working in DP in 64-bit mode with old projects and my current templates that had a UAD instantiated. This will make mixing old projects rather difficult.
- chris
- chris
- Gravity Jim
There must be something wrong with the software install. Or maybe your UAD-2 card needs to be reseated.
In this situation, I'd probably try the Uninstall/Reinstall procedure for UAD, to make sure the drivers and plugs were A-OK. Obviously they should work, and do, even with your current OS.
http://www.uaudio.com/support/uad/troub ... l-mac.html
If that didn't work, I'd reseat the card.
Jim Bordner
cwalcott wrote:well, i'm sad to say that UAD-2 is not working in DP in 64-bit mode with old projects and my current templates that had a UAD instantiated. This will make mixing old projects rather difficult.
- chris
as others have said, it should work in SL10.68, did you enable the UA plugs (as 64bit)via the DP plugin manager?
anytime I've had a problem with UAD, a quick phone call to their awesome support staff has always gotten the problem solved, they are very good.
I'd call them up.
- cwalcott
they are working, just not with old projects. i can't bring up an old mix in 64-bit.
This is a shot in the dark - can you open the old projects in DP 8 in 32-bit mode?
If you can, there may be a tiny possibility that since those old projects used
an older version of UAD (pre-64 bit), in 64-bit mode you are looking to instantiate versions of the UAD plugs which didn't exist at the time you
created the old projects.
I know, it sounds whack, but it may explain things.
http://www.davepolich.com
- cwalcott
that makes some sense but it seems a bit odd. i'd think that you'd want to instantiate the plugins that are on disk since that's what gets loaded at startup time. and DP always does a plugin check when it starts up and finds new plugins. i think there's something else in the project that is pointing to the wrong thing. it's a bug for sure but i won't hold my breath for them to fix it.
anyway, i'm sure the projects will open up just find in 32 bit mode. hopefully i won't have to go back to them very often or at all. <fingers crossed>
- chris
- chris
