8.03 memorymeter
stainless
8.03 memorymeter
Post by stainless »
maybe I never noticed before, but I uploaded/installed 8.03, repaired permissions. Everything seems to work fine (although I have had 1 crashes... I think I was maybe changing plugs on the playback... :banghead:
I notice the memory meter in DP now shows 75 = 80% memory usage, yet when I look at the usage in the Mac, it has yet to go above 2.5 GB (I have 16)
I'm thinking I should ignore this as it never seems to change (new session, no tracks, large session, lots of track, plug-ins...)... reminds me of the live mic schtick "is this thing on?!?"
I did see James mention trashing the analysis folder in the session- should this be a regular practice? how would if affect the session?
thanks
MacPro 2 x 2.4 (5,1 2010) , 16 GB RAM, 4.5TB, 10.9.1 OSX, DP 8.05, RME FF800, Audient ASP008, Lucid 8824 (clock), UAD2, JBL4623L w/sub, Prism, Avalon, Universal Audio, Aphex, Altex Lansing, AEA, Bellari, AKG, Audio-Technica, Rode, Shure, Granelli Audio, MXL, Jolie mod, JBridgeM, HearBack, and a manx named "get off the keyboard!"
Gravity Jim
Re: 8.03 memorymeter
Post by Gravity Jim »
If you see a memory meter, then you're running DP in 32-bit mode, right? In that case, the memory meter is inaccurate. It's been discussed elsewhere on the forum, but as I understand it, you should ignore the meter.
Jim Bordner
stainless
Post by stainless »
ah yes... i still have a couple of favorite plugs that are only 32...
Radiogal
Post by Radiogal »
jBridge is working great as a 32to 64bit plugin bridge if you wanna switch to 64 bit.
stainless
Post by stainless »
Radiogal
I seem at a loss where/how to get the path for JBridge into said scanning folder
JBridge scanned and seemed to find every VST I have (including demos which reminds me I need to clean those out)
DP isn't seeing any more VST's now than before I installed JBridge
the 32 bit plugs I like are the IK CSR suite and Drumagog (which I use mainly as a trigger with the click)
Radiogal
Post by Radiogal »
You need to activate them in the Preferences/ Audio plugins window as your primary plugin setting probably is AU.
You need to activate and select the bridged 32 bit VSTs one by one.
chaim
Post by chaim »
The meter is for how much memory "DP" has left for itself. Not how much the mac has left.
And the limit seems to be 3 GB not 4.
Mac Pro 2X quad core 2.26 Ghz, 22 GB RAM, OS 10.8.4 | DP 8.05 | 2408MKII
Beta Tester for Toontrack
dpg4macman
Post by dpg4macman »
I had to move the bridged plugins from the user library/audio/plugins folder to the system library/audio/plugins folder. I created a new folder in the vst folder for bridged plugins and dropped them there. After booting DP open preferences select plug ins and scroll to vst and make sure to select the newly bridged plugins. They should now be available to use.
Hope this helps,
mvh
stainless
Post by stainless »
thanks everybody!
