I'm attempting to use DP Control on my iPhone in DP 7.24. I've used it successfully in the past (many months ago), but now I notice in Control Surface Setup, it defaults to 'EuCon' as the driver. And when I click the '+' button, nothing happens. No dialog appears no pop ups, no new driver options, nothing. I can delete the EuCon driver using the '-' button, but again, nothing happens when I click '+'.
Where'd the OSC option go?
OSC not appearing as driver option on Control Surface Setup
OSX 11.6.1, DP 11.02, Metric Halo ULN-2, Plug-Ins and stuff.
Re: OSC not appearing as driver option on Control Surface Se
Try reinstalling DP to restore any control surfaces or if you have a Time Machine backup see if they're available. There somewhere obvious in the /Library/Audio folder. They're in a subfolder named something like MOTU Control Surfaces - don't have the Mac available right now.
DP8.06 PT11.2.0 VEP 5.3.x
Thanks. I do have a Time Machine backup, but couldn't seem to find anything like a Library/Audio/MOTU Control Surfaces directory in there.
Maybe when you're back in front of the MAC, you could forward the path. I'll keep searching in the meantime.
/Library/Audio/Plug-Ins/MOTU Control Surface
Hi,
I have this problem as well, I am sure it only started after I installed DP8, I do not remember a EuCon driver in DP7 but there is in DP8. Ironically I can setup the iphone control app in DP8 with no problems but have been unable to get it working again in DP7.24.
Steve
Steve
2018 3.2 GHz 6-Core Intel Core i7 16GB. External SSD Sample Drives. macOS Monterey 12.2. MOTU 624 & 8D. Cubase Pro 11, Wavelab Pro 11, DP 9.52, DSP Quattro 5. Arturia, Gforce, iZotope, NI, Plugin Alliance, Slate, SSD5, Soniccouture, Spectrasonics, Spitfire. Novation 61 SLMKII, JBL LSR 305, Sennheiser HD600, AKG 240MKII. PRS, Martin Guitars, Mensinger Bass. Vox & Orange amps. Line 6 Helix.
