"Demo" Version of 8.01?!! I'm a 25 year+ register...RESOLVED
buzzsmith
Post by buzzsmith »
Today, I was working on a simple stereo track edit and when i duplicated the track (so I wouldn't lose my raw edits in case of possible changes after the merge) I get this...
DP DEMO1? by Buzzy Smith, on Flickr
When I OK'd the window above i got this...
DP DEMO2? by Buzzy Smith, on Flickr
Buzzy
EDIT: To further check it out, the same windows appeared when I duplicated again just to see what would happen.
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Re: "Demo" Version of 8.01?!! I'm a 25 year+ registered user
Give me your Yamaha C7 and I'll fix you up with a new copy...
Seriously, I'm sure MOTU will fix you up.
Last edited by MIDI Life Crisis on Fri May 10, 2013 7:00 am, edited 1 time in total.
FutureLegends
Post by FutureLegends »
So it wasn't 8.02?
If it's 8.02 maybe you accidentally downloaded the demo version of DP instead of the regular update?
Or are you using DP on more than one computer? (I think you're allowed to install DP on two computers but only use one at the time).
buzzsmith
Post by buzzsmith »
No, I haven't downloaded 8.02 yet and it's only on one computer.
Maybe this is some code written in 8.01 (and supposedly inactive) in anticipation of 8.02 and the downloadable demo version and I just did some combination of events that triggered it.
Apparently not a real big deal. I continued working with DP as usual after dismissing the dialogs. I did do a repair disk and repair disk permissions shortly thereafter which I had planned to do anyway.
Buzzy
Focal Twin6 Be(s)
Agent of Random
Post by Agent of Random »
From the wording of it, I'd say that error is coming from a plugin, not DP (error messages tend to have the app icon of the parent app even if it is a plugin generating the error.) Maybe check the plugins on the track?
Maybe try adding a new instance of each plug in the project, and see if one in particular seems to result in that error
buzzsmith
Post by buzzsmith »
Could be. The only demo that I'm running is the Blue Cat Audio meter which will briefly stop functioning in demo mode and then resume...and the startup "demo message" when I first pull it up.
Buzzy
Focal Twin6 Be(s)
bralston
Post by bralston »
Yeah...that is an error from a third party plug being used in that session. Not an error originating from DP.
I would look at any and all plugins first.
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
buzzsmith
Post by buzzsmith »
bralston wrote:Yeah...that is an error from a third party plug being used in that session. Not an error originating from DP.
Cool. I've been running it all day and no issues. I had just never seen that Dialog box before.
Buzzy
Focal Twin6 Be(s)
