Hi folks,
I just upgraded to DP8.02 and Mountain Lion. It's great, but I'm having a problem with direct hardware playback.
It's not working. Monitoring thru effects works, but I need the direct hardware playback.
All of my settings seemed to be the same as before.
Any thoughts?
Thanks, Jim
Direct Hardware playback problem Solved!
DP 11, High Sierra, Mid 2010 Mac Pro 3.33ghz, 32gb Ram
Re: Direct Hardware playback problem
Is the option not available for selection (greyed out)? It's only available for MOTU hardware. If it's selected and you're using MOTU hardware, check your 'Audio Patch Through' setting.
DP8.06 PT11.2.0 VEP 5.3.x
Re: Direct Hardware playback problem Solved!
Updated Motu Mark3 driver.
It's always something.
Thanks,
Jim
Thanks,
Jim
