Presonus Studiolive as Audio Interface
mjmoody
Post by mjmoody »
I'm having no luck setting up Studio Live as an Audio Interface. I've seen it mentioned in the forum a few times. I have downloaded the latest drivers but my MOTU Audio Setup doesn't recognize it.
If I ever DO get it functional I would eventually like to Daisychain a hard-drive with my "sounds" to the Presonus - and I'm wondering if that's possible.
Also, I apologize for my last post - I hope James deletes it and that's not too much of a bother. I can't figure out how to edit it on Tapatalk, and my school blocks all forums, so I am stuck using my iPhone.
MacBook Pro (Retina, 15 inch, Early 2013)
2.7 GHz Intel Core i7
16 GB 1600 MHz DDR3
Digital Performer 8.05
UltraLite (2007)
Komplete 7, Omnisphere, IvoryII, and other VIs
Dwetmaster
Re: Presonus Studiolive as Audio Interface
Post by Dwetmaster »
It's to tell what's wrong with your system just by reading this. Can you be more specific? It should be easily working. I Use DP/Studio Live 24 all the time and it works great.
So don't let go, you'll get it.
mjmoody
Post by mjmoody »
Well, that's reassuring. I will keep plugging away at it.
16 GB 1600 MHz DDR3
UltraLite (2007)
mjmoody
Post by mjmoody »
DP is recognizing the Presonus as an Audio Interface. The Presonus is not appearing in my MOTU Audio Setup like my Ultralite does, but it is available under the Hardware Driver menu.
However, I can't seem to find a way to Daisy-chain my hard-drive containing all my sounds. I have a Lacie FireWire hard-drive that contains most of my VIs. With my Ultralite I just connect the hard-drive to one of the FireWire ports and I hook the computer to the other port, and my computer then "sees" the Lacie Hard-drive.
The PreSonus StudioLive has two FireWire ports, but when I hook the Hard drive to one and the computer to the other, the computer does not recognize the Lacie Hard-drive. Is there a way to Daisychain the hard drive?
John
MacBook Pro 2007
DP 7.24
16 GB 1600 MHz DDR3
UltraLite (2007)
