I'm looking to purchase a new DAW, I'm currently a Logic Pro user but I'm just so bored of it. I know that's probably a terrible reason reason to purchase another DAW, especially seeing as how adept I am with it. I've just been so incredibly uninspired lately and Logic looking so damn boring doesn't help.
I spend about 90% percent of my time in the Piano Roll/ MIDI editor window so I want it to be detailed and easy to use. Before I go hunting down vids and whatnot of the Piano Roll/MIDI editor being used I would like to first confirm if these are or aren't possible, some are pretty much expected but I just want to make sure
1) Is there some sort of "Chase long notes/sustained notes" setting so that the MIDI notes will still sound even if you start half way through them?
2) Is there a setting so you can move the counter around by just clicking anywhere on the MIDI arrange area, rather than having to either drag the counter or move up and click in the measures area where the top of the counter is?
3) Will the note sound when I:
a) First draw it in with the pencil tool?
b) Click it and drag it around to audition the notes I am moving to?
c) Raise/lower the velocity so I can audition the different velocities?
Also if you would please just watch about 10 seconds of this video to see exactly what I mean by my next questions:
http://www.youtube.com/watch?v=DNPUr8h5CZc (sorry I couldn't get imbed to work)
4) Can you switch to a different instrument with some sort of track selector within the MIDI editor? Like in the video they are all on the right and he just clicks them to change to them
5) Can you solo/mute different tracks within the MIDI editor without having to go and do it in the sequencer/arrange page or mixer?
6) When you have different instruments MIDI data showing together; can you give separate volume or modulation curves (in the area at the bottom) to each instrument? Or is it a globle thing and every curve will effect all the instruments which have MIDI data showing in the MIDI arrange area?
7) The listen tool (I believe it is called the "scrub" tool in DP?) can you use it to test the sound of all the instruments together or will it only sound the instrument you currently have selected?
Well...I think that's it ha ha. Thanks for anyone that takes the time to answer. It would be a big help even if you only answered a question or two with a simple yes/no
Sorry if this is the wrong section of the forum to post this.
All the best
Darryl
