Older MOTU parallel/series units - to PC with serial?
Steve Fogal
Post by Steve Fogal »
Hi, I've searched for HOURS on this....
I can connect an older MOTU parallel/serial unit to my older PC with a parallel port on the back plate ok via the MOTU's 25 pin parallel port & is working ok...
But, my newer PC has only has a 9 pin serial header out directly on the mobo. At 1st I thought/assumed the serial port on older MOTU's was only for MAC's...but after days of researching I read an article with just a 'slight mention' saying that older MOTU's can be connected to a PC via it's parallel 'OR' it's serial connection...? But so far I have NOT been able to find any other mention on the entire internet. Does anyone know if this is true? I'd really like to use it on my newer PC.
Oh, using Win XP still. Mobo on my newer machine (old by todays standards) is a ASUS P5KC with a 9 pin serial pinout connector on it. Yes, I did read I may yse a PCI to parallel card, but running out of PCI slots for my old Aardvark cards.
Steve Fogal
Re: Older MOTU parallel/series units - to PC with serial?
I found that article I mentioned above, regarding the mention of connecting a MOTU to a PC via the 9 pin serial port, as well as parallel port. It's an SOS article, so I assume that it's acurate that the serial works as well as the parallel.
Here's that article...
http://www.soundonsound.com/sos/1997_ar ... mtpav.html
If the serial actually works for a PC like the parallel, I wonder why it's not plastered all over the internet? My DAW is only about 6 years old and as I mentioned, has a serial pin out on my mobo, but not a parallel...so surely there must be PLENTY of people (silent apparently connecting their old MOTU units this way?
I guess I'll just have to buy a 9 pin serial pinout header adaptor & serial cable & try it myself...or I'll hokd my breath until I hear a reply :roll:
