828mkIII Hybrid - OSX 10.8.3 - Bemused
cookra
Post by cookra »
Hi All,
So..... I have two 828mkIII Hybrids connected to my iMac one via Adat to the other, then USB. All of this is setup as it should in cueMix etc..
The problems i'm having is that whenever I restart the iMac the setting in Motu Audio setup are lost, for some reason the internal audio never works until I change the setting Main Out Assign. Which leads me to another odd point, at the moment I have music playing but only via the Main Output Assign set to Analog 1-2, whereas yesterday internal music would only play if the Main Output Assign was set to Main Out 1-2..
The whole setup just feels very un trustworthy at the moment. In fact this morning I had no sound at all and the iMac didn't recognise the 828's using FW or USB, a restart was the only option...
On a final note, it just feels like I have a really un happy imac since I installed the Motu drivers.. I eve tried a complete reinstall of the OS...
Is this just a me issue or anyone else in the same boat?
I've updated both units to the latest firmware also...
:deadhorse:
NazRat
Re: 828mkIII Hybrid - OSX 10.8.3 - Bemused
Post by NazRat »
DP8.06 PT11.2.0 VEP 5.3.x
cookra
Post by cookra »
Thanks.. Didn't search the forum :surrender:
sergeybrin
Post by sergeybrin »
I told you about the problems with the drivers that reproduce ML on MOTU known. You OVAT a work in progress. I 828mk3 ML and not the Voice Select Settings panel after every reboot again.
