Changing banks with Avid/Euphonix Artist Mix Dp 8.01
DaveB
Post by DaveB »
I've recently purchased an Artist Mix and am running it with DP 8.01 in 64-bit mode. Everything is working except that when I use the Bank and Nudge buttons on the Mix, the tracks in the DP mix window won't follow or update to match. If I select a track (or multiple tracks) in the DP tracks window the Artist will follow.
I'm using Eucon software v2.62 as I found that with the newest version (2.7) the Artist wouldn't even follow a track selection made in DP. I've also re-installed DP after installing the Eucon software to get the latest Eucon bundle (1.9) - as recommended in other threads.
I'm wondering whether I need to change a setting in DP to get this to work? Has anyone else got the Nudge/Bank buttons to work?
8-core MacPro 4,1, 32 gb RAM, OS X 10.9.2, MOTU 8 Pre, DP 8.06, VePro 5
