Please help : Loosing Movie in 64bits ???
Hi,
Movies play fine when using DP8.01 in 32bits mode.
In 64bits, windows remains black, no movie (same with severals type of movies, all working fine in DP8.01-32 bits)
My system is "clean" ... except that I have both Quicktime 10.2 and 7.6.6 : could it be relative ?
Any ideas ...?
Thank you,
Emmanuel
MP early2008 2x2.8Ghz, 20Go, 10.2.8, DP8.01
Any ideas ...?
Thank you,
Emmanuel
Re: Please help : Loosing Movie in 64bits ???
no one ...?
Because movies work fine on my setup with DP8.01 at 32 bits, I imagine the 64 bits may be in cause ?
I've checked in Activity Monitor : when running DP in 64 bits, there is a "DV Out" process, linked to "Digital Performer Process (3032)" running at 32 bits.
Could someone running DP8.01 at 64 bits (and playing movies without problem) confirm me that this DV Out process (32 bits) is a normal behaviour ?
It would help me to investigate.
Thank you,
Emmanuel
Thank you,
Emmanuel
DP8 cannot play .dv movies AFAIK so that means no streaming to the FW port. I just use Quicktime movies as I can send them to a second monitor. Should be fixed soon.
OK, but I just try to play regular .mov inside DP (no FW external monitor) : I never had any trouble with the movie window in DP since years .
But now, I just get a black empty movie window when launching DP8.01 in 64 bit mode.
(sorry for my english)
Emmanuel
Emmanuel
Contact MOTU. It is working fine here, just no .dv files., only .mov files are working.
thank you, I'll call MOTU.
Just for laughs, have you repaired permissions since installing?
- bralston
We should have a new drinking game. Every time MIDI Life Crisis recommends someone to repair permissions for a DP8 issue...take a drink.MIDI Life Crisis wrote:Just for laughs, have you repaired permissions since installing?
(That's a joke now MLC....and I agree with it)....
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
Brian Ralston
I get it, I get it...
... and it does solve a lot of problems. Drinking, that is...
Re: Please help : Loosing Movie in 64bits ??? (Solved)
Solved after a re-install of Moutain Lion via recovery partition : movies now play fine in 64 bits mode !
I didn't know that the recovery partition let re-install the system without erasing datas, app, pref etc (I was ready to manualy restore from TM backup), a real time saver !
Thank you
Emmanuel
Thank you
Emmanuel
Just want to mention - I had a similar problem and solved it the same way. A half hour unattended, all settings saved.
Macbook Pro 13" 2011 8gb Ram, DP 8, OS 10.8.2
TC Electronic Konnekt 24d
- Shooshie
Wow. Congratulations. Things are getting better in this tech world, aren't they?
Definitely a lot smoother than days of yore.
