Hi everyone!
New MOTU-user from Sweden, so sorry for bad spelling at times.
My new laptop from ASUS does not connect to the 4pre. It is like something is interfering. I have an old VAIO with vista and when i tried the 4pre on that computer everything worked fine.
The ASUS is from the series Asus A55A, quad core i7, win 7 ultimate with 64 bit system, USB2 connection.
When I install everything it says that it is working fine and everything. I got volume on the mics but I can't record anything and I can't listen to anything through the monitors.
What more info do you need? What should I do? Bad drivers?
I appreciate every help I can get.
Cheers / Cim
Problem with MOTU 4pre and win 7 64 bit USB2
Re: Problem with MOTU 4pre and win 7 64 bit USB2
Someone who can help me?
I've tested it on two other computers now and it works with vista and win 7 home premium.
Is there any known errors running it with win 7 ultimate 64 bit?
/ Cim
/ Cim
Can the cumputers motherboard be incompatible with the 4 pre? It seems pretty far feched or what Do you guys think?
Found the problem!
What was the problem?
