This is my fist attempt posting here, so greetings to you all and thanks in advance for any asssistance you all might be able to provide. Also, to the moderators, if this should be moved to a more appropriate location (I checked but didn't notice a more relevant area)please do so, or let me know how and I will do it.
K, here goes:
I am currently in the process of final Mastering some tunes prior to thier release on I-tunes. I'm using Audio Desk 3 and have bounced all of the tracks in each of the individual songs down to 2 stereo tracks. So now I'm basically in the "fine tuning- finishing" mode which requires very small tweaks and a light touch. In one of these tweaks I applied a "Trim" effect to to the Stereo mix, which not only allows you to set the max peak, but also permits you to make one side of the mix (either you chose) to be out of phase with the other side. I tested this with interesting results. It actually made the mix sound deeper, and more broad or stereophonic, giving the instruments a seemingly broader location in your hearing prespective, almost like they were located out beyond the actual range of the speakers you were listening to. It also seemed to throw certain instruments (in a high end vehicle sound system) into other speaker locations such as the rearmost, making you feel as if you were sitting in the middle of the music, not just having it come at you from the front. After rsearching a bit regarding these dynamics, I discovered this is an old trick used by sound designers for ages to produce these exact results. However there are some questions regarding this:
1.
I've also heard you can do this same trick by reversing the polarity in one of the stereo tracks. How would one accomplish this with Audio Desk. and what would the difference be?
2. Are there any drawbacks to this phased method? I know that in a mix with both mono and stereo tracks combined you can suffer drop outs in tracks due to this, does this affect a pure stereo track though? Am I losing anything here?
3. And finally, will this cause an issue when this isn't played on a regular stereo system, say a car or home system, but is transfered to an I-tune or Mp3 to be played on systems perhaps of lesser complexity?
Any assistance is most welcome.
TIA
S.
