Live Room G vs Guitar Rig vs Me :)
Wazatron
Post by Wazatron »
Hi all - I'm hoping to learn more about amp modeling, and how you all are using Live Room G. I'm historically a player transitioning into more of engineering side of things. Oh, and to get it out of the way since someone always asks: yes, I've searched through the forums and have done a ton of research already. :) So... anyone who would like to help out I'd love to hear from you. If not, feel free to move along.
It's my understanding that when using Live Room G as a true amp simulator, it's best to record direct through a DI box at least, or HIz input on your AI, etc. And then build a DP signal chain that mirrors your real-world counterparts.
However I'm having a hell of a time getting what I would consider "real" sounds of of these steps, and I can't help but wonder if I'm missing something, or if my expectations are out of whack.
I've also done some experimenting in trying to build the "same" rig in DP 8 and Guitar Rig 5 (where there is sufficient overlap in amps, pedals, etc.) and while I certainly didn't expect the results to sound EXACTLY the same, I found I couldn't get them sounding anywhere even possibly remotely close to each other. But if they are both touting that each component sounds just like the real thing, etc. shouldn't they at least sound pretty close? Again, maybe it's just me.
So at the end of this post, my real question is kind of twofold: am I doing things the correct way, and perhaps I just still have a lot to learn in the details? Or perhaps am I out in left field here trying to get caught up on all the amp modeling. :) I've been looking for some good training resources, but so far can't find anything overly specific on this topic, so any suggestions on perhaps where else I can dig would also be appreciated.
Thanks everyone!
crduval
Re: Live Room G vs Guitar Rig vs Me :)
Post by crduval »
Hey Wazatron
I'm not an amp sim expert but I've played around with the DP plugs a little. Like you, I was a little puzzled as to how exactly to get a good approximation of a mic'ed up amp, so one thing I did was by starting with the channel presets. There are quite a few of them, covering all kinds of styles.
I wouldn't say I was ready to sell my amps after that , but I did get a better idea of how to get the best use out of the plugs that way.
BTW I do use a DI into my MOTU I/O. Most recently I've taken a bass through a DI and and a preamp, then used the DI to feed a third bass channel using some of the plugs (in this case to create a really saturated bass track) to create a single bass part. You can get some good results that way.
Good luck!
M2 MacBook Air, DP11, MOTU MX-4, MOTU Mach5, EWQLSO Platinum, Acoustic Samples B5, UAD Waterfall Organ, EWQL Platinum Pianos, UVI Falcon, UAD-2 Duo, MOTU Ultralite mk5, K2600XS controller
Wazatron wrote:I'm having a hell of a time getting what I would consider "real" sounds.
I have the same reaction with most simulators. I've used various guitar amps since the 60s, and never thought much about any of them at the time. When I started using amp simulators, none of them sounded much like amps I'd ever used (with a few simple exceptions: a clean JC 120, a clean twin reverb, a heavily distorted anything). At best they capture one or two of the main characteristics of recognizable sounds, so at least you can guess what they're trying to sound like.
My conclusion is they're not meant to sound like real amps; they're meant to sound like a recorded guitar track when they're in a mix. So I guess they're OK as long as you're using them in a mix.
Scuffham is the first exception. I can hear hints of the complexity and response of real amps there.
