no option to create a loop
dang47
Post by dang47 »
i just dragged my first sample into M5 3 and i do not have the option to "create a loop" in the drop down menu, and yes i have selected it in the sample window and i cant seem to find the answer in the Sample chapter in the manual either....the one shot mode on or off doesn't seem to effect if the "create a loop" appears in the menu.
help please :oops:
Re: no option to create a loop
First off, you can go to your double post, select edit and delete it. If you get an answer there, then James will have to do it.
Second, which drop down? This can be confusing. Have you tried control-clicking on the graphic of the wave? there should be a loop option down there.
dang47
Post by dang47 »
ya sorry for the double post, i dont know how i did that...i tried to delete it but i do not have that option...... in the "right click contextual menu i can not find "create a loop"
dang47
Post by dang47 »
only when i drag and drop i cant get the option but if i go thru the lengthy browser and import it that way i get the option.... and also im i to understand i can not drag and drop from the soundbite window or from the sequencer time line? i have to export soundbite first??
