The thing is that you can't boot from it. IIRC, you'd have to boot from your OS DVD, and then it'll copy all the files from the TM disk.Prime Mover wrote: I was under the impression that TM backups are handled essentially like clones. Is that not the case?
You'll need to make absolutely sure that TM is set to backup ALL your files and system files as well (you can verify this in TM's preferences.
It's totally doable too, and, IME, it has worked fine (I've recovered my laptop and my girlfriend's system like this with no problem).
The only thing is that I've also had a TM backup error... Only once, though.
You could nuke and reformat your disk and recover it from TM. It should work just fine. Also, I suggest repairing your disk and the permissions with Disk Utility just before your last TM backup, just to be safe.
