Transcribing MIDI + Freeze + DP8
mirmidon
Post by mirmidon »
It happened today for the first time:
With the QuickScribe window open, at the moment when the page is about to change for the successive one, this appears
and nothing more happens, DP just freezes.
I have waited for 15 minutes and nothing changed, not even the scrolling bar scrolls……
In the dock there is "The application is not responding" instead of "Quit" and I have to force quit.
I have restarted DP various times and then the Mac too, and the problem still persists.
I did not found nothing about this in the user manual.
I don't understand what means "Transcribing MIDI", what MIDI there is to transcribe?
I think that it could be a problem with the VI RealGuitar, but I am not sure.
Thanks for any help
Edit:
1) The culprit is not RealGuitar, as the problem occurs even removing the VI.
2) In DP 7.24 all works perfectly.
mirmidon
Re: Transcribing MIDI + Freeze + DP8
Post by mirmidon »
Thank you for your so numerous answers :D :D
urbansonic
Post by urbansonic »
Hello
I have the same Problem ... only when "show aranged score" is enabled and going to the next page or when i want print it.
:smash:
i try now do the same with dp7 and dp8 32bit mode
greetz!
Urban
urbansonic
Hello again
DP8 32bit
freeeeze
DP7.24 works... the popup before printing show a different title "Transcribing Line Breaking" need a minute but dont freeze. while printing the same popup again :? wait a minute... printer start
greetz Urban
urbansonic
You have to Limit the number of scales to the maximum you need... mini menu -> options -> set score length.
then it should work
i dont know how long the score lengt can be, but in my project it was to long
but dp7 dont freeze in same project ... its also a bug in dp8 for shure.
