For anyone using HS and DP, have you been able to get the portamento control feature to work? I've tried following the manual, using the specified controllers, experimenting with their placement and values, etc., but nothing seems to make this feature work predictably and consistently. Sometimes I get no portamento at all; sometimes a note slides down to the note rather than up to it from the preceding lower note. Sometimes the timing of the affected note is delayed. It just seems that it's almost impossible to make this work correctly.
Are there known issues with Hollywood Strings, Play, and Digital Performer? I've put in a support request to EastWest, so I'm hoping someone can offer some insight about this issue.
I'm using DP 7.24 and Play version 3.0.32. (I just checked and there's a Play update I'll install.)
Richard
DP and Hollywood Strings (portamento issue)
- remmet
Mac mini 2018 3.2GHz i7; OS X 15.2; 64 GB RAM; DP 11.32; Apollo X6; Kontakt; Omnisphere II; Adagio Everything, Spitfire almost Everything, Berlin Winds and Brass, Xosphere 2, and endless other sample libraries, acoustic and electric guitars, and assorted other essentials that have helped make me the "almost break even guy" my accountant so admires.
Re: DP and Hollywood Strings (portamento issue)
Issues with Play? Yes, there are. It's been buggy from its inception,
and although some issues have been dealt with, I think there are still
a number of bugs.
This is definitely a question for EastWest tech support. It's not DP because
you'll find the same problems with Play in other DAW's.
Hope they answer your tech question soon..
a number of bugs.
http://www.davepolich.com
- Steve Steele
Do you have HS Gold or Diamond? I don't have an answer for you but I'm curious which one you have. Thanks.
- remmet
nightwatch wrote:Do you have HS Gold or Diamond? I don't have an answer for you but I'm curious which one you have. Thanks.
I've got HS Diamond.
And I have not heard back from EastWest.
Richard
