Motu828mk3 can not play flash video / javascript
motu_user_77
Post by motu_user_77 »
I have Motu828mk3 firewire with XP64 professional with the latest driver. The problem is not new but now it has become unbearable to use it.
Any action caused by javascript on a website causes the motu to produce a high-pitched peep-sound that halts all other sound programs that are currently running. It also halts the whole system for several seconds.
Flash video (vimeo.com etc) stutters unacceptably and it halts all other audio that is playing. It replacing the signal with a constant high-pitched frequency tone. My ears hurt from it. It can not play longer than 2 seconds. Youtube video works as long as i don't play full-screen. That sometimes works, sometimes not.
The flashplayer driver or the motu driver update is the only thing i can think of, but this problem is not new. It only got worse.
torrentg
Re: Motu828mk3 can not play flash video / javascript
Post by torrentg »
Flash doesn't have a driver, my friend.
I experience a very similar issue and my system is in outstanding shape with regards to its setup/drivers.
When I watch YouTube at 480p, which I have been able to do for years with no issues on this system, it is flaky....but when I put it to full screen, it freezes the whole system and I too get that high pitched squeal.
I have been trying on here to get MOTU to look at it.
If I feel up to it, I will completely disable the MOTU from the system and test if the same thing happens with my onboard Realtek AC '97.
I shall give results here if I do.
torrentg
Post by torrentg »
Well I just did my little test. I powered off the MOTU then rebooted.
My system had the same exact problem with the onboard Realtek, so I don't think MOTU is to blame for this.
Another interesting thing I noticed is that 480p works perfectly fine on the videos that use HTML5 instead of Adobe Flash.
Believe it or not, I just got a 0x9C MCE stop error when testing the Flash above. That usually means a bad CPU but that's complete nonsense. I do a million other things all perfectly on this machine, including many of the latest games. Never any issues. It's only Flash stuff causing problems. See for yourself:
Code: Select all
*                        Bugcheck Analysis                                    *
MACHINE_CHECK_EXCEPTION (9c)
A fatal Machine Check Exception has occurred.
KeBugCheckEx parameters;
    x86 Processors
        If the processor has ONLY MCE feature available (For example Intel
        Pentium), the parameters are:
        1 - Low  32 bits of P5_MC_TYPE MSR
        2 - Address of MCA_EXCEPTION structure
        3 - High 32 bits of P5_MC_ADDR MSR
        4 - Low  32 bits of P5_MC_ADDR MSR
        If the processor also has MCA feature available (For example Intel
        Pentium Pro), the parameters are:
        1 - Bank number
        3 - High 32 bits of MCi_STATUS MSR for the MCA bank that had the error
        4 - Low  32 bits of MCi_STATUS MSR for the MCA bank that had the error
    IA64 Processors
        1 - Bugcheck Type
            1 - MCA_ASSERT
            2 - MCA_GET_STATEINFO
                SAL returned an error for SAL_GET_STATEINFO while processing MCA.
            3 - MCA_CLEAR_STATEINFO
                SAL returned an error for SAL_CLEAR_STATEINFO while processing MCA.
            4 - MCA_FATAL
                FW reported a fatal MCA.
            5 - MCA_NONFATAL
                SAL reported a recoverable MCA and we don't support currently
                support recovery or SAL generated an MCA and then couldn't
                produce an error record.
            0xB - INIT_ASSERT
            0xC - INIT_GET_STATEINFO
                  SAL returned an error for SAL_GET_STATEINFO while processing INIT event.
            0xD - INIT_CLEAR_STATEINFO
                  SAL returned an error for SAL_CLEAR_STATEINFO while processing INIT event.
            0xE - INIT_FATAL
                  Not used.
        2 - Address of log
        3 - Size of log
        4 - Error code in the case of x_GET_STATEINFO or x_CLEAR_STATEINFO
    AMD64 Processors
        1 - Bank number
Arguments:
Arg1: 00000000
Arg2: 82d25dac
Arg3: 00000000
Arg4: 00000000
Debugging Details:
   NOTE:  This is a hardware error.  This error was reported by the CPU
   via Interrupt 18.  This analysis will provide more information about
   the specific error.  Please contact the manufacturer for additional
   information about this error and troubleshooting assistance.
   This error is documented in the following publication:
      - IA-32 Intel(r) Architecture Software Developer's Manual
        Volume 3: System Programming Guide
   Bit Mask:
       MA                           Model Specific       MCA
    O  ID      Other Information      Error Code     Error Code
   VV  SDP ___________|____________ _______|_______ _______|______
   AEUECRC|                        |               |              |
   LRCNVVC|                        |               |              |
      6         5         4         3         2         1
   3210987654321098765432109876543210987654321098765432109876543210
   0000000000000000000000000000000000000000000000000000000000000000
   Concatenated Error Code:
   This error code can be reported back to the manufacturer.
   They may be able to provide additional information based upon
   this error.  All questions regarding STOP 0x9C should be
   directed to the hardware manufacturer.
BUGCHECK_STR:  0x9C_GenuineIntel
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  FlashPlayerPlu
CURRENT_IRQL:  1f
LAST_CONTROL_TRANSFER:  from 8301b2c5 to 82cdb490
STACK_TEXT:
82d25d8c 8301b2c5 0000009c 00000000 82d25dac nt!KeBugCheckEx+0x1e
82d25eb0 8301b4cb 00000000 00000000 00000000 hal!HalpMcaReportError+0x81
82d25ed0 8301b5d6 00000000 86b13068 82d25ff0 hal!HalpMceHandlerWithRendezvous+0x89
82d25ee0 830115f5 00000000 00000000 00000000 hal!HalpHandleMachineCheck+0x34
82d25ff0 8300e261 00000000 801ca000 00000000 hal!HalpMcaExceptionHandler+0x87
82d25ff0 00000000 00000000 801ca000 00000000 hal!HalpMcaExceptionHandlerWrapper+0x89
motu_user_77
Thank you for this reply torrentg. You seem to have the exact same problem as I have.
I also notice that the sampling frequency changes when opening a video or when a program like a screensaver takes action. Then it is like an 48 khz sound is played at 44 khz, but then while the motu is set on 44khz. Resetting the frequency in the motu console fixes this.
What i will try to do is downgrade to a lower version of adobe flashplayer plugin. I will update here about the results.
torrentg
Post by torrentg »
Well, here's the deal...
You should inspect your motherboard for capacitors that are leaking with brown crud on top or bottom (electrolyte) or ones that are just not perfectly 100% flat on the top.
If you have anything like that, it is likely the cause.
I pulled the motherboard out here and replaced 3 caps. About a week ago, my system was freezing every hour or less or so. After I replaced these 3 caps, it is 100% perfect expect for Flash! I mean, I play games for hours on end!
There is another definite bad cap or two that I did not replace (yet) - so I have a strong feeling that this could be my issue, despite the system having perfect uptime when Flash is not in use.
So...
You're welcome! And do you have any blown capacitors on the motherboard?
motu_user_77
I uninstalled flashplayer , and downgraded to version 9, 10.1 , 10.3 with no change: still the horrible frequency peep-tone whenever some flashplayer action is present on the screen.
I uninstalled my video driver and tried to downgrade it but then i lost my network (nvidia drivers uninstall also uninstall windows drivers and this is not easily fixed). No change at all. The horrible frequency is still present.
I can not fix my windows xp64 setup anymore, so i bought windows 7 and a new harddisk and i am now on a new OS with the latest drivers for motu 828mk3, flashplayer, and my videocard. Now I Can Not Play Music Anymore without every 10 seconds a sharp 6000Hz beeping tone interrupting all sound in an unacceptable manner.
I'm furious and desperate at this point. Playing a html5 video results in only stutter and beep tones that might blow up both my ears, my motu and my mackie monitors. What to do, except throwing the thing out of the window ?
torrentg
Post by torrentg »
Have you inspected the caps carefully yet at all? Both on the motherboard and video card.
Any bsods ever?
motu_user_77
Re: Motu828mk3 useless on windows 7
Sorry for the late reply as my mixer (soundcraft) broke down and was in repair.
I replaced the Windows XP64 setup with windows7 enterprise edition
The same problem occurs; and dissapears after i uninstalled the NVIDIA geforce 8400GS driver. Now -without an active NVIDIA driver- the sound works just perfect. I will update when i have found a driver version that works on this system.
