New fans for MDD!?!?!
tdblanchard
Post by tdblanchard »
what brand replacement fans would you recommend for an MDD that would bring it down to a tolerable level?
i've been hunting and hunting and all i can find is this outfit in germany that has a mod kit for like 200 euros!
i just recorded vox for the first time on it and man, that puppy's loud!!
beubbo
Post by beubbo »
HELL YES ! ... TELL US WHERE ? ... PLZ ! ...er... WHAT ? ... why am I screaming ??!?
I'll tell you why, just have to shut down before this bloody "lovely-old-grey-Apple-Box" !
btw, totally agree with you man.
so every single help would be GREATLY APPRECIATED ... WHAT ?!?
oh well
Tritonemusic
Post by Tritonemusic »
beubbo
Post by beubbo »
666,
Thanks man ! :)
musicmanphil
GET CHUD TOOLS 3.5.2 !!!!
Post by musicmanphil »
This is a guranteed miracle fix for the MDD noise problem. Forget fans (they obviously can only help), but this is all you need to fix the problem with the MDD's.
Search for "CHUD Tools" on google. You will find a link to a page on Apple's web site.
DOWNLOAD CHUD 3.5.2.......not 4.2.2. ONLY 3.5.2 will work!
After you install check your System Preferences panel. Look for "Hardware" at the bottom. Click it and enable the NAP check box.
That's all. You should notice a SIGNIFICANT temperature drop and noise reduction in less than 1 minute.
tdblanchard
thanks a bunch.
i actually just got chud over the weekend and it helps a bunch..
buzzsmith
Post by buzzsmith »
musicmanphil...
Just installed CHUD 3.5.2 and clicked the Nap button within the System Preferences>Other>Hardware dialog box.
Thanks for the tip!
Fan noise dropped dramatically within 90 seconds or so!
Running iPulse, I saw temps slightly increasing from about 135 to 137.9 degrees, generally remaining steady within this spread after 15 minutes or so....right this minute: 137.3 degrees.
What is the generally acceptable temp operating range for a MMD 1.25 ghz dual G4?
(just being cautious)
=bz=
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
trippa
Post by trippa »
wow! I've had the Verax power supply fans sitting under my desk for ages, but installing them requires a complete removal and dis-assembly of the power supply, so I'd never found the moment to put them in.
Installed the CHUD tools and just listened as my fan noise went down to about half the level I've grown used to since getting the MDD 1.25 over a year ago.
Great tip!!
.......CT :lol:
tdblanchard
trippa wrote:wow! I've had the Verax power supply fans sitting under my desk for ages, but installing them requires a complete removal and dis-assembly of the power supply, so I'd never found the moment to put them in.
Great tip!!
.......CT :lol:
if you want to unload those verax fans...
shoot me a message.
