Just to let you know, I was not intending on posting here again but since you directly posed a question to me here goes....
Example 1)
You start off admitting that there is no pre/post roll option in this configuration, so there's strike 1
Second, you're method has the user holding down the "i" button while clicking in the timeline. I hope you know all this is doing is temporarily selecting the time range tool if it is not already selected.
Two problems are presented with your 3rd step. First of all, what was the point of clicking on the timeline to set an insertion point if right after that you type in the desired location in the counter and move the insertion point to the location you just entered in the transport counter? That makes no sense. Why not just skip the second step entirely?
musicarteca wrote
Atention: this is not a selected range, it is a point.
Exactly, and you know what this means, Audition from selection start will not work at all so there is no work around for the pre-roll option
Now we get to the good stuff.... all the points that show just how much you haven't been listening.
After step 3, your suggestion results in
exactly the same problem that I spoke on in my
first post.
This is what you said..
musicarteca Wrote
3- On the counter type in the desired location.
4- Press command-period. this will move the insertion point to the counter location.
This is what I said...
However, to keep this functionality working, I have to hit the command "Enter Counter In Memory Start" EVERY TIME that I change my playback location.
The only difference now is, in your suggestion, I am hitting the command "Enter Counter in
Selection Start" EVERY TIME that I change my playback location. woo-hoo
"As a result, it is always a 2-step process to change my playback location to achieve proper functionality."
Same exact problem I spoke on in my first post, and repeatedly spoke on throughout this entire thread.
Oh, but its not over yet...
In Example 2, Memory Play and Link Selection to memory are enabled. This sounds familiar...
Hmmm, "repeat from steps 2 to 4 above." In the above situation, you are using command + spacebar to initiate playback from the selection start time. Have we forgotten the bug that is present when Memory Play is enabled, that screws up the Play from selection start command?? Maybe I should quote myself again.
The other configuration I tried that was close but not right was to enable memory play and use the Memory Start and End times as Playback Start and End times (which is what it is configured to do). However, this renders the transport counter completely functionless as anything but a time display because playback is continuously controlled by the Memory Start time field and this proposes 2 problems. 1st, there is no shortcut to edit the Memory Start field (the shortcut to edit the transport counter is Apple+T) so every time I need to adjust my playback location, I have to manually navigate my mouse to the tiny entry field on the control panel.
The second problem with this method is the "Bug" where the command "Play from selection start" does not properly work whenever "Memory Play" is engaged in the control panel. The "Play from selection start" command will only work when the transport is already running. Again, this "bug" only occurs when "Memory Play" is engaged. Upon initially entering the command, playback will begin from the regular Memory Start time and you have to hit the command a 2nd time in order for DP to properly execute the command.
And you want to know another problem with this "example 2"
try this one out.
1)Enter a playback location of bar 10 in the transport counter and use the 2-step command to copy it to your selection start.
2)Now I want to change my playback location so enter bar 8 in the transport counter and use the 2-step command to copy it to your selection start. Now your selection start time is bar 8, but your selection end time is bar 10. And since memory play and link selection to memory is enabled, DP will
only play back these 2 bars...
And still it gets better... say I go the extra step, and either make sure that the selection start and end times match, try using a pre-roll right now. DP will play up until your selected playback location and stop. Awesome
You know what. I've really got to hand it to you on this one. You really added something constructive to this topic and shed some new light on me. I mean, its not like you just repeated
everything that had already been discussed. Because that would just be proving my point again now wouldn't it?
musicarteca wrote
Now please explain to me "again" why this works perfectly well for me, but it doesn't work for you. You think it takes a long time? Try it out! Go ahead, try it and count the milliseconds.
Here I go repeating myself again. I love it.
"You are use to the 2-step process that I find annoying. You have accustomed yourself to a workound that you should not have to use."
"My optimal workflow will be different from yours and everyone else••™s. "
" You are missing the point entirely of this entire thread! I did not start this thread asking for workflow suggestions.
""I started this thread to find out if there was a way to configure DP's transport to a specification that I feel only makes common sense to have, and I found out that it doesn't. I'm cool, because my question is answered.""
As a recording engineer running sessions for high paying clients, it is all about speed. I can't stress that enough. Say for example, I am zoomed into to a pre-chorus for overdubs. The client says, let me hear the last 4 bars of the guitar solo real quick. I am not going to say, "Ok, Mr. High Paying Client, please wait a moment while I zoom out, click on the timeline, link that to my counter, and begin playback." Please.
Is this economic climate, its all about being able to hold on to your high paying clients and influence them to come back. They are paying hundreds to thousands of dollars an hour (depending on the room) and trust me,
every millisecond counts.
musicarteca Wrote
Give me a solution better and quicker that what I have just described.
Your solution is a mess. And most importantly, it was not answering the question that I started this thread for. How's about quoting myself 1 last time
"I started this thread because I thought there could be an option that I hadn't found, to select this method of transport."
""I have said at least 6 times that I now know the answer to the question I came here for and I'm ready and willing to adjust my workflow....
I was done with this issue 2 days ago, but I have to keep repeating myself to people who either won't read my earlier posts, or just aren't listening."
Now it••™s getting to the point where I don't even have to type in new text, I can just quote myself. Oh yeah
