DP 8 and M-Audio ProFire 610 Input Issue
sonicflight
Post by sonicflight »
Hi All
Using Digital Performer 8 on a 64-bit system. Have the ProFire 610 interface and can't see inputs 3 and 4. It shows SPDIF and Inputs 5/6 (but doesn't have 5/6). I tried uninstalling the drivers then reinstalled, but to no avail. I've got another unit and it does the same thing. When I'm in the ProFire Control Panel, I see all the inputs and outputs (with signal levels), but just can't see them in Digital Performer.
Please help....!!
THanks!!!
Gary
Radiogal
Re: DP 8 and M-Audio ProFire 610 Input Issue
Post by Radiogal »
Be sure you enabled all these O/P and I/P from your hardware setup software. Also check DPs Hardware setup under the Set Up meny and be sure you have selected the right interfaces.
You could also check Bundles in DP and see if these are shown there.
