Crash Report - Can someone tell me what this means?
dpg4macman
Post by dpg4macman »
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 ...akt 4.MusicDevice.component 0x48abd3ce ComboKnobSubForm::init() + 78
1 ...akt 4.MusicDevice.component 0x4814c1ad NI::NGL::SubFormControl::onInit(NI::NGL::Form*) + 109
2 ...akt 4.MusicDevice.component 0x48ad68ce SmartControl::onInit(NI::NGL::Form*) + 30
3 ...akt 4.MusicDevice.component 0x48abf6ea ComboKnob::onInit(NI::NGL::Form*) + 26
4 ...akt 4.MusicDevice.component 0x4819c43c NI::NGL::Form::addControl(NI::NGL::Control*) + 172
5 ...akt 4.MusicDevice.component 0x48ba21fc ScriptUIModuleBase::createControls() + 1740
6 ...akt 4.MusicDevice.component 0x48bb177e ScriptUIModuleBase::SyncToEngine(bool) + 3710
7 ...akt 4.MusicDevice.component 0x48b99880 PerfViewModule::SyncToEngine(bool) + 1104
8 ...akt 4.MusicDevice.component 0x48c2a4d9 InstList::ArrangeSlots(UIManager*) + 1705
9 ...akt 4.MusicDevice.component 0x48c2d80b Multi::OnUIMessage(UIMessage*, int) + 587
10 ...akt 4.MusicDevice.component 0x48c0f7eb UIManager::DispatchMessages(bool) + 907
11 ...akt 4.MusicDevice.component 0x48b32ec1 KontaktFormManager::onEvent(unsigned int, NI::UIA::EventData*) + 1217
12 ...akt 4.MusicDevice.component 0x481a3246 NI::NGL::FormManager::sendEvent(unsigned int, NI::UIA::EventData*) + 86
13 ...akt 4.MusicDevice.component 0x48d7fe0a NI::NGL::Window<NI::UIA::AUWindow>::onEvent(unsigned int, NI::UIA::EventData*) + 106
14 ...akt 4.MusicDevice.component 0x48d7f88d NI::AU::EditorNGL::onEvent(unsigned int, NI::UIA::EventData*) + 45
15 ...akt 4.MusicDevice.component 0x4810bfcf NI::UIA::EventTarget::sendEvent(unsigned int, NI::UIA::EventData*) + 31
16 ...akt 4.MusicDevice.component 0x4810c3b6 NI::UIA::DETAIL::EventTimerSubscription::tick(unsigned int) + 118
17 ...akt 4.MusicDevice.component 0x480fd085 NI::UIA::Application::processTimer() + 101
18 com.apple.CoreFoundation 0x94e34a3b __CFRunLoopRun + 8059
19 com.apple.CoreFoundation 0x94e323c4 CFRunLoopRunSpecific + 452
20 com.apple.CoreFoundation 0x94e321f1 CFRunLoopRunInMode + 97
21 com.apple.HIToolbox 0x97cf3e04 RunCurrentEventLoopInMode + 392
22 com.apple.HIToolbox 0x97cf3bb9 ReceiveNextEventCommon + 354
23 com.apple.HIToolbox 0x97e7c084 _AcquireNextEvent + 54
24 com.apple.HIToolbox 0x97e71d40 RunApplicationEventLoop + 228
25 com.motu.DigitalPerformer 0x005d709a 0x1000 + 6119578
26 com.motu.DigitalPerformer 0x00003806 0x1000 + 10246
27 com.motu.DigitalPerformer 0x0000372d 0x1000 + 10029
Frodo
Re: Crash Report - Can someone tell me what this means?
Post by Frodo »
What version of Kontakt are you using?
Also, what controllers or control devices were in use at the time of the crash?
It looks like a user interface mishap, but your sig also shows DP6.x in use. There were "issues" with DP6 which stumped a lot of users. I would first recommend getting into DP 7.2x or later where many of these issues were fixed quite handsomely. Troubleshooting DP6 could be a lesson in futility.
dpg4macman
Kontakt 5 with Steven Slate drums on three instances, also running BFD Eco one instance, Sonik Synth 2 one instance. The crash happened when I was in the Drum editor and selecting patches. Crashed 3 to 4 times. I was blaming it on my lack of ram (Mini 2g ram max_I know I need an upgrade) DP6 has been working pretty much flawless up until I started using the Drum editor. I am using a MOTU 828 FW interface and Axiom 49 controller with 4 external FW drives.
Thanks Frodo
Frodo
Post by Frodo »
I'm still pondering. I want to get to the bottom of this one big time.
Scratching my chin....
kgdrum
Post by kgdrum »
I've haven't been able to get any IK synth,SonikSynth2,Sampletank or Sampletron to pass validation in DP8.
I didn't read your crash report but as much trouble as I had with the IK synths and IK telling me to wait for ST3 so I can use these with DP8 I suspect SS2.
I'm also puzzled that I couldn't get these working at all and you have........
kgdrum
Post by kgdrum »
Duh,just noticed you're using DP6.
I bought the DP6 upgrade & never opened the box or installed it,there were just too many reported issues.
I went from DP5 directly to DP7.
Frodo
Post by Frodo »
Yeah. DP6 was somewhat of an "oopsie". I don't have it any more and can't do any tests in it.
What is your OS?
Frodo
Post by Frodo »
dpg4macman wrote:Kontakt 5 with Steven Slate drums on three instances, also running BFD Eco one instance, Sonik Synth 2 one instance. The crash happened when I was in the Drum editor and selecting patches. Crashed 3 to 4 times. I was blaming it on my lack of ram (Mini 2g ram max_I know I need an upgrade) DP6 has been working pretty much flawless up until I started using the Drum editor. I am using a MOTU 828 FW interface and Axiom 49 controller with 4 external FW drives.
Thanks Frodo
Yes, knowing the OSX version would help. 2GB used to be a luxury once upon a time, but MOTU recommended 2GB for DP7 as a starter kit before adding third party plugins. That is likely the benchmark for DP6 as well.
If I'm not mistaken, at least some of those MINIs share memory for graphics and the system. On my laptop, OSX uses about 800MB, which is *almost* half of your resources before booting DP.
Some thoughts:
1. Try to avoid having a lot of windows open at once, and avoid running other apps concurrently with DP.
2. You might want to disable any plugins and VIs you never or rarely use, including all formats.
3. Depending upon your model of MacMini, there could be a RAM upgrade for you that could help, but I'm not 100% sure. It depends on the model, but it seems that this is possible on 2007 models and later. Companies like Other World Computing and Data Memory Systems have been offering RAM sticks for a lot of Macs that exceed Apple's official RAM max limits. It might be worth it to talk with a rep just to see what's possible or available for your machine. It could certainly serve as an affordable interim solution short of buying a newer model computer. My 2007 MacBookPro cites a max of 4GB, but I'm running 6GB with no problem.
kgdrum
Post by kgdrum »
+1 @ what Frodo said,as always ;-)
2gig ram limitation is a big part of the problem,it doesn't help that you're using Slate which is resource demanding as well as DP6 which most DP users will say upgrade to at least 7 ASAP
dpg4macman
Thanks everyone for the responses - I've since started a new session/template using one instance of Kontakt 4 instead of 3 sessions of K5 and one BFD along with SampleTank 2. I set up my drum kits assigning The kick, snar and toms to different MIDI output channels on one Kontakt instance (I probably should have known this - right) I created a template for my drum editor and it is working fine now. I'm sure it was me having to much going on with limited resources. Oh yeah, I loaded SampleTank instead of SS2.
Thanks again,
mvh
PS: system 10.6.8
