Splash Screen??
stephentayler
Splash Screen??
Post by stephentayler »
About half the time that I start DP8, I get no splash screen as it starts up...... otherwise it works fine... DP appears top left in the menu bar, and then the next thing I see is the folder containing the last file I worked on.
Anyone else getting this? Otherwise I don't seem to have any problems at all....
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Re: Splash Screen??
Are you sure it's not already running, and page swapped out?
stephentayler
Re: Splash Screen??
No, just tried it again - same result!! No programs running already........
Stephen
stephentayler
Re: Splash Screen??
update:
switching to 32bit brings the splash screen back - all seems normal
quit and switch back to 64bit - no splash screen but DP loads in less than 10 seconds......
curiouser and curiouser!!!
SWT
Re: Splash Screen??
You found some secret programmer's preference.
stephentayler
Re: Splash Screen??
indeed - I'm not complaining!!!
SWT
stephentayler
Re: Splash Screen??
after all that - tried again in 64bit - got the splash screen and DP loaded in about 5 seconds....
SWT
Re: Splash Screen??
Might have been in a cache from the last load. Like loading from SSD, only faster.
Re: Splash Screen??
Post by Shooshie »
My splash screen did not work after the DP 8.01 update. There were some other problems as well, so I repaired permissions and all was well again. I posted about that episode somewhere around here.
So, after all that the splash screen worked a couple of times, but it stopped working again. I'm going to try cleaning out caches and see if that makes it reappear.
Shoosh
Dan Worley
Re: Splash Screen??
Post by Dan Worley »
stephentayler wrote:after all that - tried again in 64bit - got the splash screen and DP loaded in about 5 seconds....
SWT
Now you're just bragging. :surrender:
DP10.13
