DP and HUI mode
toodamnhip
Re: DP and HUI mode
Post by toodamnhip »
By the way, in the eucon control panel, under workstations, it is showing up as “unknown002.....” should that read Digital Performer?
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
toodamnhip
Re: DP and HUI mode
Really weird.
If I make automation move with EUCON, I see that the data gets written inside of DP in a track. But on play back, DP doesn;t follow it. If I manually grab the plug in parameter it writes the data in the track the same way but DP reads it upon play back.
Weird.
In this example, we’re talking treble boost in a waves plug in
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
toodamnhip
Re: DP and HUI mode
Hey Stephen, I have moved this discussion over to a thread specifically about Artist Mix. This thread was supposedly about HUI and I wanted to have others who have artist mix be able to see the thread.
http://www.motunation.com/forum/viewtop ... 69#p443479
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
FMiguelez
Re: DP and HUI mode
Post by FMiguelez »
Hey, guys.
I've been following the thread from a distance. Very interesting (and promising) stuff.
Basically, you confirmed my suspicions: HUI mode sucks! Especially that deal with the track banks.
I like the solutions and other protocols you've mentioned, so I'll check them out, even if they are much more expensive.
