Access 828mk3 Built In DSP from DP?
screws
Post by screws »
I just posted this question on the Motu Hardware Forum, but since it relates to DP I thought I'd put it up here as well. Hope that's OK.
Since the new 828mk3 and 896mk3 (and a couple other) interfaces now have built in DSP that can be accessed from CueMix, has anyone found a way to access those features (eq, comp/limit, fx) directly from DP, bypassing CueMix entirely?
Might be a nice, low-latency way to do live automated shows with just a laptop and an interface, rather than using plugins while routing live mics through DP for eq, compression and fx.
Steve Cruz
Florida
Steve Cruz
Cruzified Music Productions
Florida
Re: Access 828mk3 Built In DSP from DP?
For live work, why not use CueMix? If you do, you will not be alone, I assure you.
screws
Post by screws »
I'd gladly use CueMix, but according to the Tech I contacted at MOTU, CueMix cannot be controlled from DP, and the whole point is I need to automate the eq, faders and fx in CueMix.
I hoped someone knew whether the onboard DSP in the newer MK3 i/o's could be accessed directly from DP so I could automate for a live, fully automated show.
Or is there a plugin that emulates OSC? TouchOSC is the only way to externally control CueMix at this time, according to the same Tech.
Steve Cruz
Florida
