Enabling sends on a V-Rack
- cwalcott
Does anyone know if it's possible to set up a bus send on a V-Rack? For instance I'd like to route a selection of V-Racks to one reverb. I can't use the individual V-Rack outputs in this situation.
- chris
- chris
- waitsongs
Re: Enabling sends on a V-Rack
When I create a V Rack in DP7.24, I get two sends, ready to assign anywhere I want. Perhaps there's a preference to increase the number of sends if you need them, but looks like at least two are available by default in the same place you'd find them on a normal audio track. Hope this helps.
DP 8.06, OS X 10.8.3, 8 core 2.8gHz MacPro, 14 GB ram, 32 Lives and JBridge, UAD-2 Quad Satellite, 828mk3, Apogee AD-16X, Trak2 and Rosetta, Eleven Rack, EWQL Gold Pro, Colossus, Goliath, Ethno World 4, StormDrum2, Komplete 8, LASS, MX4, Soundtoys Bundle, Stillwell plugs, Ozone 5, Slate Bundle, Trash, Waves C6, H-EQ, Autotune, Abbey Road plugs, Pro Tools 10, Logic 9, Reason 6.5, Final Cut Pro, lots of mic pre's, mics, instruments....
- supersonic
Looks like only two are available in the V-rack. You can have 20 aux sends per channel in the sequence but I haven't found a way to increase that number from 2 in the V-rack.
Music is movement in silence
You can set the number of sends in a v-rack the same way you set them in any mixer window mini menu. Goes up to 20.
bayswater is right and I also think you won't need sends since you can add aux tracks to a v-rack too. In that case you can just bus all of your VI's to an aux track with effects in the v-rack. I think the trick to both of these solutions is to open the v-rack in it's own mixer window. Then when you add a track or change the number of sends it applies to the v-rack in the window and not the main sequence.
Digital Performer 2.7 - 8.0, Logic 9, PT 8, MacBook Pro Core i7 16 gig, Quad Mac Pro 6 gig, Mac Mini 2 gig, Roland XP-50, Kurzweil K2000, MOTU 2408 MK3, MOTU Mach 5 II, Ethno
- Shooshie
Aux tracks make good return tracks from the V-Rack. Unless you want your sends to be the same for every chunk that uses the V-Rack, the Aux makes sense to use for the sends. But sends are just as usable in the V-Rack as elsewhere, as others have pointed out.
By the way, in case you haven't seen it in the prefs, you can view your V-Rack in the same mixing board with the Sequence Tracks. Or, if you prefer, you can just use the key-command to access the V-Rack. I leave mine open all the time alongside my sequence tracks.
