Frodo wrote:KG-- I have a 30" monitor. It's not a monitor issue. I think MOTU confused basic resolution aspect ratios with what you're talking about. I concur with your concerns.kgdrum wrote:
I have a 20" Mac Display(dvi) I got with my G5.in consolidated window I can't get the whole screen,it cuts off on the far right.
Would I see the entire window of DP if I moved up to a 24" screen?
I've been told by MOTU tech support that DP is designed for a larger screen.....
But, it's not altogether a bad thing. For one thing, MOTU seems to be on fire with doing fixes, based on the results of the 8.01 release. There are a couple of twiddles that they might want to look at for 8.02, but the current update is impressive.
What you (and I) have experienced is perhaps a quirk of OSX in which goodies in DP can actually exceed the capabilities of the OSX GUI, if that's possible. If you have all options selected for the Control Panel, you will not see them all no matter how far to the right you stretch the window (even if you drag half or more of the window off to the left of the screen). I don't know if this is strictly an OSX issue or if it's some quirk in the GUI developer kit that was overlooked (or otherwise not available).
The short answer: No, you are not crazy.
short reply,yes I am crazy
Longer answer:
I never used or liked the consolidated window previously,maybe because I don't totally "get it".
I streamlined my setup the last few months from 2 monitors to 1 & I'm trying to try to approach DP from a different perspective.
Kind of force myself to use DP differently as I've felt limited and in a rut. I'm trying to create a self inflicted DP and music paradigm reset.
I might try Shooshies approach of using spaces to have virtual monitors or I might just try going back to using 2 monitors,I'm really not sure,for now I'm trying to see if I can get used to the Consolidated Window concept.
Thank both Bayswater and Frodo for the info.
