Stop Button Appears to Stick
meredithsdg
Post by meredithsdg »
Looking for suggestions on this one. On occasion, the stop button appears to stick. I use the number pad on the computer keyboard (0, 1, 3 and ENTER) for stop, rewind, record and play. Sometimes, looking at the monitor, after hitting the ZERO key, the STOP button appears to be stuck down. If I press ZERO again, the button releases and everything is fine.
If I've hit ZERO and don't notice that it stuck, and then press DECIMAL and put in a measure number, nothing happens because the STOP button was stuck. When I hit ZERO again to unstick the button, the measure number is entered that I put in during the stick.
If you read my post about the live performance disaster, I assumed that this behavior was related to the TASCAM 428, which is now retired. I was using DP this morning with USB directly to the Kronos and it happened again.
Any ideas?
iMac i7 Quad Core, 8Gig Ram, DP 8, DP 7.24, MachFive 3, Virtual Steinway, Real Guitar 2.1, Finale 2011, Sound Studio 3.6.1, iPad (3) 32GB 4G, MOTU 896HD, Fastlane, Korg Kronos 73, Casio PX-5S
http://sdgministry.com
Re: Stop Button Appears to Stick
• Try using the commands window to set it to a different key to determine if it's the keyboard, DP, or some combination of the two.
• Try another keyboard.
• Clean the contacts under the key or at least blow it out if you haven't already.
meredithsdg
It's definitely not the keypad causing the problem. I've had it on 2 laptops, with the onboard embedded keypad, wireless bluetooth keypad and a usb keypad.
daniel.sneed
Post by daniel.sneed »
I've been thru some trouble with transport commands a while back.
Sometimes DP is waiting for the button release.
My workaround was:
- click data entry place in command window
- press button
- click anywhere in empty space in command window
- release button
Then you're sure DP will listen only to press and will forgive release.
Hope this may help.
