Gravity Jim wrote:Some things to keep in mind:
1. Perhaps more people who come to this Forum are reporting these problems than not. That doesn't mean that a majority of DP users are having problems. People aren't likely to log here to tell everybody how perfectly the software is running: except for a small group of regulars they come here because they're having trouble.
Hi Jim,
Over the years I've kind of gotten a feel for whether a problem is widespread or not. The keyboard problem is more common than most problems we see here. In 2005 I created a database in Excel, and put out a questionnaire for our members in order to track down a disturbing bug that everyone else had, but that I did NOT have. It was surprising what all we learned from that adventure. First, it's a heck of a lot of work. 2nd, it confirmed the frequency of its occurrence, and showed that the problem was extremely widespread, 3rd, it showed absolutely and without doubt what was causing the problem. Once we knew the fix, it was easily fixed, and everyone's problems cleared up.
But what caused me to do the database was realizing that being one of the few who almost never experience problems, it was too easy for me to pretend that problems are because of something someone else is doing, and that it's their fault, so I really shouldn't worry about it. I decided to do something, to track down, find, and eliminate the problem once and for all, even though I didn't have it. The whole experience made me a lot more sympathetic to others' problems, as well as intuitive about which ones are genuine, which are user error, and how widespread they are.
If we don't get results on the update which MOTU will probably put out in the next month or two, then I'll probably repeat that database, and do another questionnaire. It really is the only way to positively identify the cause of these things, short of having the code and debugging software.
Back in 2005, the results of that data mining showed that a new driver that MOTU had delivered was the culprit. 100% of respondents with that driver had the problem, and 100% of people with the problem were using that driver. I bundled up my drivers in a .zip file, offered them to the forum, and the problem was solved. I'm sure this time it's something similar. I just hope that MOTU finds it, because doing those questionnaires and mining the data in a spreadsheet in Excel requires a lot of work and time. A lot more than I've got to give. But if it takes that..
Until then, please understand that we're dealing with a major bug, and that those who don't have it should be supportive of those who do.
Thanks,
