How to connect an external mic preamp to Motu 2408 MKII
hk_lydian
Post by hk_lydian »
Sorry for that newb question. I am using Motu 2408 Mk2 as an audio interface and converter, I am planing to buy a vintech 73i mic pre. Is it possible to connect the output of vintech 73i to 2408 analog input directly (at the back of the unit, there have 8 balanced 1/4" analog inputs) ? or any other suggestions? Thanks
G5 dual core/2G ram, Tascam DM24, Motu 2408MKII, DP 7.22, AKG C3000, C1000, Wave Diamond, Machfive 2, Ivory Piano, EZ Drummer, Real Guitar, Trillogy Bass, Kontakt 2.
Re: How to connect an external mic preamp to Motu 2408 MKII
Yes. Most preamps plug into the Line inputs.
What Mike said. Definitely use a balanced connection if at all possible.
hk_lydian
Post by hk_lydian »
Thank you so much.
Somebody advised that I can connect the Vintech X73i to the mic input of my Tascam DM24 but switched off the phantom power and turn the gain to zero. Is it a good idea or will it cause distortion?
hk_lydian wrote:Thank you so much.
"Somebody" is wrong. It still goes to line inputs.
hk_lydian
Post by hk_lydian »
Thank you mike, got it.
