Themes - the solution to DP7 to DP8 conversion
dinobass
Re: Themes - the solution to DP7 to DP8 conversion
Post by dinobass »
Thanks, GG; that's what I was wondering, and it'll be a nice stop-gap until Andy's update.
Mac Studio M2 Ultra 128G RAM OSX 14.3, 16" MacBook Pro M1 Max, UA Apollo x6, UA Apollo Twin, UAD-2 Satellite (x2)
dinobass wrote:Thanks James, but I should have been clearer in my request. I made the changes to one of the AmpGUI themes to make it compatible with DP8, but in the Consolidated Window none of the tabs show up; they are still there if you click around, but they are invisible. This is true whether the Control Panel is embedded or not.
That's unfortunate. I seldom use the Consolidated Window, so it doesn't really affect me that much. I'm content to wait until Andy has the 100% DP8 compatible versions ready.
Post by Shooshie »
I found that some of the themes experienced this worse than others. Gotham's tabs are still clearly visible, though dark. I keep the Control Panel floating, so that it can go from Space to Space, so there's no problem with it. Only the new embedded CP has trouble with the old themes. The floating one still looks exactly as it did before. I'm back in AmpGUI almost as if nothing changed. What a relief!
Shoosh
