Motu 896HD - Problem with the headphone switch.
Solvik
Post by Solvik »
Three days ago I bought a used Motu 896HD. It's now installed and seems to work pretty well on all the inputs and outputs. Exept one thing that I can't understand.
Beside the volume pot I got this switch for Main Out + Phones/Phones Only.
When I'm inside Cubase and I set the switch to Phones Only the output on the main outputs rushes up to like 85%! And when I then turn the pot it only controls the headphone volume and indicate this at meter 7 (meter 8 is at maximum all the time), but the volume on the outputs remains awfully high.
(With the switch in mode Main Out + Phones the volume knob control both the main out volume and the phones volume. I think this is how it should work, even if it would be pleasent if it just controlled the main out volume)
As I understand there is no obvious way to reset this, so how should I start to troubleshoot this problem?
/Oskar
Solvik
Re: Motu 896HD - Problem with the headphone switch.
Post by Solvik »
Anyone?
hswin
Post by hswin »
Hello Solvic,
I have 3 MOTU 896HD's and have the same problem as yours. I think it is inherent. If I am recording a live band, I usually take a headphone amplifier and push it that way. If I take my Ultralight, I can connect the headphone out of the 896's into unused inputs of the Ultralight and it works well there.
Hal
Having fun with 32 tracks in OKC
hp laptop zd7000 2.8 Ghz 2 Gb DDR RAM
XPP SP3 with AVT1394 FW drivers
Sonar 8.31P
MOTU 896HD (x3)
MOTU Ultralite
many studio mics
email: hswin@att.net
