how to apply a setting change to multiple tracks
- cwalcott
i'm trying to figure out how to apply a setting change to a selection of tracks.
say i have 8 audio tracks and each track has 2 takes. i want to select all 8 tracks and change them all from take 1 to take 2. or i want to select all tracks and change the inputs from whatever they are set to, to none.
what happens is when i select a set of tracks and change the take, it only changes the one i'm clicking on, not the set.
is there a way to do this?
- chris
- chris
Re: how to apply a setting change to multiple tracks
Grouping should do it.
- cwalcott
awesome. that did the trick. thanks!
- chris
- chris
No problem. Look into it. You can turn it on and off temporarily and more. It's worth reading the whole chapter in the manual.
- Shooshie
Temporary groups:
• Hold down the W key while you perform an action, and it will perform that action on all visible tracks.
• Hold down the T key, and it will work on all selected tracks.
You may have to set the group actions for temporary groups in the Groups Window.
If the W and T keys are not working for temporary groups in DP8, restart DP8. There is a bug currently in DP8 because of which the keyboard randomly loses focus for various commands. Hopefully, MOTU will be addressing that in an update, soon.
- cwalcott
ohh, that is an awesome trick about the T and W keys. I'll remember that and i plan on reading that section of the manual.
thanks for the help!
- chris
- chris
