DP8 Disaster
- Primary DAW OS: Windows
DP8 Disaster
My DP8 package arrived today and I am stunned. There is no INSTALL disc in the box! The add-on disc is apparently there, although it will not open because my PCs (tried all three) think it is an empty disc!!!
The disc that did arrive was sitting LOOSE IN THE BOX, with no case or envelope. Unbelievable!
If that wasn't enough of a screw-up, I ordered a Rom Chip upgrade for my MicroLite USB interface, so I could port it over to my new mega-PC for the new software this week. Following the instructions carefully, I installed the chip BACKWARDS and spent two days trying to figure out why my PC couldn't recognize it. I am sight-impaired, but I finally got a magnifying glass out and realized that the notch was supposed to be on the RIGHT, while the instructions from MOTO clearly say the LEFT.
All of this just transpired today, an hour too late to call MOTU. Seriously, this is painfully unimpressive. I have been using MOTU products and Performer exclusively, since v1.4 What a let-down, MOTU!
palestrina7
Professor of Music
Utah State University
palestrina7
Professor of Music
- hammerman
Re: DP8 Disaster
The PC version of DP 8 is not out yet. Soon, and you will get it. Read here:
http://www.motu.com/newsitems/dp8-is-now-shipping
There's only one shipped disc in the box right now and it is the Mac version.
Re: DP8 Disaster
The Windows version of DP8 is not released yet. If you put the disc in your PC it's probably not reading it because it's for Macintosh. Contact MOTU.Palestrina7 wrote:My DP8 package arrived today and I am stunned. There is no INSTALL disc in the box! The add-on disc is apparently there, although it will not open because my PCs (tried all three) think it is an empty disc!!!
palestrina7
Professor of Music
Re: DP8 Disaster
A harbinger of things to come?
with apolgies, somewhat sincere.
Re: DP8 Disaster
I'd hoped he would respond back and say it was "pc" he was trying to load and mark this link SOLVED
Mac Pro 4,1, OS 10.9.5, 2.93 GHz Quad-Core Intel Xeon, 32 GB 1066 MHz, DP 8.07, Apogee Ensemble, UA SOLO 610, Euphonix MC Control & MC mix, JBL Monitors, Ocean Way Drums Gold, Komplete 7, Waves Classic Studio Bundle,Stylus RMX, iZotope RX,1TB glyph Drive, Carvin 6 string Bass
http://www.HorizonEntertainment-NC.com
Re: DP8 Disaster
Nope. The DVD is blank. My G5 can't read it, either. Says I can burn files on it.
Thanks for the correct info on the delivery, guys, but that is not what I was told when I called MOTU. In fact I told them I not to bother sending me the Mac version. The fact that the dvd is not labeled MAC is also incredibly annoying, And there is still a disc missing from my package, according to the manual.
So I guess I'll wait some more.
Re: DP8 Disaster
My Mac disc also doesn't specify. Sounds like you got a bad package but MOTU will certainly make good on it. Still sucks!
Re: DP8 Disaster
Yep... it's unfortunate. Still I've heard of people sometimes getting bad discs.
- FutureLegends
Re: DP8 Disaster
I was got a bad disc with MachFive 2. They sent me a new, and I had it in two days - and I'm in Sweden!
Maybe they didn't send the install disc because you told them not to bother with it? (and the Windows version isn't released yet)
Anyway, give them a call or email and they are usually pretty quick at setting things straight.
Re: DP8 Disaster
My first DP7 upgrade disc was bad. I contacted MOTU and they sent one out right away. Your results may vary, but I had my disc the second day. (I live in NY, very close to MOTU HQ in Mass.)
Good Luck!!!!
Good Luck!!!!
MacBook Pro 15" 2G QuadCore i7,8G RAM, 20"Intel iMac 2.4Ghz , 4G RAM.OSX 10.8.3 on both, DP 7.24, MOTU 828MK3, AudioBox 1818, KRK Rokit 6G2, Omnisphere 1.5, Komplete 8, Amplitube 2&3, SampleTank, Sonik Synth2, SampleMoog, SampleTron, Ivory 2, Philharmonik, EWQL MOR, SC, SOG, SD2, Reason 6, Waves, McDSP, Slate Digital VCC, FGX, Sound Toys.
Re: DP8 Disaster
There are supposed to be two discs? I only got one in my package..Palestrina7 wrote: The fact that the dvd is not labeled MAC is also incredibly annoying, And there is still a disc missing from my package, according to the manual.
Man, too bad about your situation. Just get with MOTU, I'm sure they will set things right for you..
Re: DP8 Disaster
They were able to fit Extra's are on the install disk so only one disk was shipped.
Re: DP8 Disaster
Palestrina7, if the disc that you've received truly says that you can "burn files on it", then someone's "messed" with your package and put a blank disc in there! It's not a bad DVD, Mac or PC, if it's able to "burn files"...it's a blank writable. Call MOTU...Palestrina7 wrote:Nope. The DVD is blank. My G5 can't read it, either. Says I can burn files on it.
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
