Cue-mix OSC documentation
I would like to be able to control cue mix from my MIDI hardware. The good news is that I use Max to run my live rig and Max has great support for OSC. That means it woud be trivial to have Max receive MIDI messages and then generate OSC packets to send to cue mix. But I woud really like to not spend time reverse engineering the MOTU implementation. Has umm, anyone else done this, or know from where I could get good docs to save time?
D
D
___________________
David Jameson, Ph.D.
http://www.deskew.com
Macbook Pro (2) running GigPerformer, Max 7 and Loopback, iPad (3), various weighted and lightweight MIDI controllers, Eigenharp Alpha, plugins from NI, AAS, Arturia, Modartt, G-Force and many others
Currently performing with The Security Project (http://securityprojectband.com) and Beyond The Wall (http://beyondthewall.net)
- rolandvg99
Re: Cue-mix OSC documentation
As far as I know there's no docs on it yet, but you could open the template of your interface in TouchOSC Editor and find the commands there. According to tech support there's currently no way of accessing a fader/button/command directly. One needs to assign stuff in banks of eight and use the channel/ bank switches to switch between channels and mix busses.
I would have loved the option to access i.e. bus 2, channel 24 directly, but atm it's not possible. Or at least not in a good working way.
OSCulator is a good bet for sniffing commands that are hidden, like mute and solo buttons. It also is an invaluable piece of MIDI/OSC translating software.
Owns a 828MKIII, 8M AVB and DP7.24 + loads of non-significant stuff.
Thanks. I did set up Max to receive and display incoming OSC messages so I can see what they did. It's just a painful way to figure it out
___________________
This is in the template:
http://pastehtml.com/view/cdh38i82b.rtxt
i extracted it with a python script
Love it!
However, I can't connect to that pastehtml site
___________________
Thanks, yes pastehtml is down now i guess...
I forgot to mention that i extracted the mk3 hybrid template
Here is the script, so you can extract a template for an other model:
http://pastebin.com/YqLLMT2k
Nice.
Thanks for providing this.
___________________
ok, here's the rest
CueMixFX-4pre.touchosc
http://www.dinkypage.com/157661
CueMixFX-AudioExpress.touchosc
http://www.dinkypage.com/157662
CueMixFX-MicroBook.touchosc
http://www.dinkypage.com/157663
CueMixFX-MicroBookII.touchosc
http://www.dinkypage.com/157664
CueMixFX-mkII.touchosc
http://www.dinkypage.com/157665
CueMixFX-PCI-424.touchosc
http://www.dinkypage.com/157667
CueMixFX-Track16.touchosc
http://www.dinkypage.com/157669
CueMixFX-mk3.touchosc
http://www.dinkypage.com/157640
The dinky site is no longer active. Could these be posted somewhere new?
bump? going on ten years and I'm just getting into this now , bah... would love to find more source code !
Reaper Mac 7.1.5 ; 828mk3 FW; 8Pre FW; 2023 MacBook Pro M2 Ventura.
2017 MacBook Pro 2.8 GHz Quad-Core Intel Core i7 16 Gb RAM OS 10.15.7 500 Gb Flash Storage MOTU M2
