DP Control Surface
Alfred Zigoma
DP Control Surface
Post by Alfred Zigoma »
Help, in Control Surface I have only driver Open Sound Control
I can not choose HUI for connection V-Control.
It occurs on MacBook Pro, has begun in any instant on 10.6.8, has now put absolutely 10.8 - the same history
What can advise?
MacPro Quad-Core 2.8 GHZ 16GB RAM OSX 10.10, MacBook Pro 13" 2.4GHz 8GB RAM OSX 10.11, Mac Mini MD388 OSX 10.10
DP 8, SSL MADI AlphaLink MX, UA Apollo, SSL Sigma, PMC Tb2, ATC SCM 20, SSL Alpha VHD Pre, Kemper, Powercore x8, UAD Octo, MC Mix(х2), MC Control, Melodyne, Revoice Pro, RX4, Soundtoys, McDSP, Waves, all Slate, VSL VE Pro, SE, Suite, NI Kontakt 5, Halion 5, MachFive 3, BPM, etc...
wvandyck
Re: DP Control Surface
Post by wvandyck »
HUI, Mackie Control, Radikal SAC do not show up in the Driver pop up?
Alfred Zigoma wrote:Help, in Control Surface I have only driver Open Sound Control
What can advise?
Before you can use vControl, you have to go to their website and downloand their app "Ney-Fi" which must run in the background on your Mac in order to use it. Go to the link below and fill out the form and download this "helper app" and it should get you there.
http://www.neyrinck.com/en/downloads/v-control-pro
What can advise?
You also need to click the little "+" in the Control Surface setup dialog to add a new control surface before you can select the driver.
Alfred Zigoma
wvandyck wrote:HUI, Mackie Control, Radikal SAC do not show up in the Driver pop up?
They simply are not present
On Mac Pro all this is and perfectly works, on MBP 10.6.8 in any instant the others were gone the driver. I have bought Mountain Lion and have established it on MBP as pure system.
Pressing + nothing gives
wvandyck
Post by wvandyck »
Alfred Zigoma wrote: They simply are not present
Did you upgrade to DP 7.2.4 on the Mountain Lion system?
All of the control options appear in DP 7.2.4 on both my Mac Pro 1,1 (OSX 10.7.4) and i5 MBP (OSX 10.8.1).
This business of upgrading is tricky. Do you have a backup clone to test DP7.24?
Alfred Zigoma
I have understood,
On new system put at once update 7.24 from account MOTU
Has now established from a disk 7,22 and all has turned out :headbang:
wvandyck
Post by wvandyck »
:arrow: Excellent news. :woohoo:
Rhetro
Re: DP Control app problems on 10.8.1
Post by Rhetro »
Hello.
Has anyone found a solution to this. I've read the instructions and can't get my dp control to work with DP 7.24 on my MacBook Pro.
Open Sound Control is enabled in my setup, my iPhone can't seem to see it for some reason. Both computer and phone are connected to the same wifi, and the firewall is turned off
iMac (3.06 GHz Intel Core 2 Cuo, 6GB/800 Mhz), Macbook (2 GHz Intel Core 2 Duo, 3 GB/667 Mhz) DP7.24, IZotope Ozone 4, Presonus StudioLive 16.4.2, Dynaudio BM 6A mkII, Yamaha NS-10M Studio, JBL 4311, one Auratone 5PSC, Alesis RA-100
