VEPro Multiple Instance Issues
I realize this is probably a Vienna issue, but I figure I can't be the only one to run into this. Basically, I open my template in VEPro 4, fire up DP...and what *should* happen is that DP connects to all my instances that are loaded. Instead, it keeps creating all new ones, ignoring the ones that already exist. I've tried preserving the new ones, deleting the old ones, etc...but every time I load the project in DP, it just keep creating new instances. This only started happening with Mountain Lion, and yes, all my software is up to date. Anyone?
Re: VEPro Multiple Instance Issues
Not 100% sure.. could be that VEP 4 isn't compatible with Mountain Lion?
Ever consider VEP 5??
DP 8.04 64bit, VEP 5 (Latest), 1 Dual Quad 2.26 Mac Pro 2009 w/ 10.8 as DP DAW. 1 Dual Quad 2.26 Mac Pro 2009 w/ 10.6 as VEP Sample Machine. PCIe 424 - 4 2408's. Console - Yamaha 02R 96v2. AD/DA - Apogee Symphony IO. Waves, Sonnox, MOTU Plugins.
i've had this before. i think it can mean that previous instances are still connected in some way and it opens newer ones. it's stupid i know. but one fix (if i recall) is to disconnect the instances then try to reconnect. I don't know if this is any help. There might be something on here or the VSL Forum about it. i've heard of others having this issue before. Also you should update to VE Pro 5 i think. Best of luck.
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
It sounds to me that you saved once your DP template with no VEPRO active...You will have to reassign the "Instruments" to your VEPRO instances and re save...make sure when you reassign and BEFORE YOU HIT SAVE ON YOUR TEMPLATE IN VEPRO that your sounds are still there and not getting disappeared.
