Arrow Key to select track to record on in the tracks window
timmeh
Post by timmeh »
I normally am able to use the arrow keys on the keyboard to scroll up and down the track list with record enable but for some reason cannot at the moment, is there a setting that I can change to enable this feature?
Hardware
Mac Pro 2014 6 core 3.5ghz, 1 TB Internal PCI-SSD HD, 64gb RAM, Focusrite Sapphire Pro 14, OSX 10.9.2, BlackMagic Multidock II (3) SSD's.
Software
Digital Performer 8, Hollywood Brass & Woodwinds, LA Scoring Strings, EWQLSO Platinum Plus, Komplete 9, Omnisphere, Trillian, SD2, Evolve Mutations 1 & 2, Vienna Ensemble Pro
bolla
Re: Arrow Key to select track to record on in the tracks win
Post by bolla »
Very occasionally this happens to me. It seems to be on projects that have large MIDI track numbers. This is idle speculation. It's never hindered me enough to spend the time finding the cause.
Cheers, Bolla.
8 Core 2.8 10.11.1 DP 8.07 | Dual 2.5 G5 VEP Slave | PC i7 920 VEP Slave | UAD Sat Quad | MiniMoog
Post by Shooshie »
There was something a couple of years ago that I found, where some other command had taken the up/down arrows and was preempting its former use as record-enable. I had to find that command and change it so that the record-enabling with arrow keys would continue to work.
To find what commands use the arrow keys, go to the Commands Window, and attempt to add an arrow key to any existing command. You'll see a dialog showing the command(s) to which that key is currently assigned. It's up to you to delete any unwanted ones.
Dwetmaster
Post by Dwetmaster »
The "Record Enable Previous/Next Track" commands
I have these commands setup to other keys and I've never encountered this problem. Try setting it up to anything else to see if it still happens.
timmeh
Post by timmeh »
Thanks for all the tips. It turns out that a folder that was closed had a bunch of audio tracks set to record enable therefore prohibiting me from being able to use the arrows keys to move up and down.
DP - 1
User - 0
DP wins on account of an USER FAIL. Hahaha, oh well at least I figured out what was going on.
Hardware
Software
Post by Shooshie »
timmeh wrote:Thanks for all the tips. It turns out that a folder that was closed had a bunch of audio tracks set to record enable therefore prohibiting me from being able to use the arrows keys to move up and down.
DP - 1
User - 0
Uh-oh. Guess that could do it. Well, it was only a temporary fail. User won in the end.
Killahurts
Post by Killahurts »
This exact thing happened to me just the other day, another good reason to put a "record enabled tracks" indicator on closed folders. If you don't have multi-record turned on, it doesn't matter, but, I always do.
