Hello,
Im trying to free up cpu in DP 4.6. I want to disable plug-ins so I can run Elektrik piano without the cpu clipping. In protools you can hit control & command and click the plug-in to disable. Is there a way to do this. Could not find anything in the manual.
Dave
How do you freeze plug-ins
DP 7.01, 2 x 2.66 GHz Dual-Core Intel Mac 4 GB ram ,Macbook 2.16 1.5 GB ram, Motu 896HD, Motu Ultralite, Powercore compact, , Reason 4.0, M-box, , MiniMonsta, UAD 2 QUAD, B4 2, Stylus RMX Guitar Rig 4,Battery 3, Universal Audio 6176, UA M-610, 2 Chandler Germanium and Germ Comp, Akg 414, Rode NT 1, Pearlman TM1, Royer 121, Cascade Fatheads 2,Rupert Neve Comp
- sdfalk
Then you didn't look to hard:
Page 181-182
That's if you're referring to freezing...
If you're talking about just turning off a plugin hold the option
key and the pointer will turn into a finger.
Then click on the insert where the plugin is located.
The font will become italicized indicating it's been bypassed.
Or you could just open up the plugin and click the bypass button.
Page 181-182
A Metric Halo ULN8-3D…mmmmmmm
- sndhse
Eric. Go to Setup/Automation setup. Under "Automation preferences"
Check the box "Mute Frees System Resources". That should help to free up some CPU cycles.
Hope that helps.
John
www.soundhousestudio.com
Hope that helps.
John
Thanks sdfalk,
Freezing was'nt the right term. You answerd my question about turning off plug-ins
