everb (mono to stereo) balance L&R?
qwerty
Post by qwerty »
Hi,
When I insert everb (mono to stereo)on a track, the overall balance of the newly stereo track tends to be quite left heavy, even more so at the master.Just wondering if anybody else has experienced this and/or can enlighten me as to why this happens and how they deal with it. Thanks
Macbook 2GHz Core 2 duo 2G memory Ultralite DP 7.24 OS 10.6.8
stephentayler
Re: everb (mono to stereo) balance L&R?
Post by stephentayler »
Perfectly balanced here, both 100% dry or 100% wet.....
How are you setting this up? I presume this is a mono track to start with, adding the mono to stereo version of eVerb?
Mystery.....
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
qwerty
Post by qwerty »
Yes Thanks! for example: a simple mono vox track panned straight up the middle. When I add everb mono to stereo, eg. 27% mix 45% stereo, it tends to be hotter on the left and also visibly so on the master. I hadn't noticed it at first but when trying to do a rough mix of something, I tried to identify where the lean to left was occurring on the overall VU balance on the master limiter by soloing various track combinations. Those with everb inserts tended to lean to the left.
Mystery indeed.I haven't found any of my settings to be suspect but might be missing something obvious or otherwise.
stephentayler wrote:Perfectly balanced here, both 100% dry or 100% wet.....
Mystery.....
Cheers
Stephen
