Hi.
I really like the effects used in Machfive. But now I'm wondering if there's a way to use them with other VST instruments. I haven't figured out how to do it. I'm using FL Studio 10.
Thanks in advance.
Using Machfive as a EFX Plug-in
Re: Using Machfive as a EFX Plug-in
I'm afraid you can't do that.
Too bad. In the future maybe.hugy wrote:I'm afraid you can't do that.
The only way to do this would be to record/bounce the other instrument, then drop the audio file into M5.... then add the effects.
Can't be done in real time though, but this does give you access to the processing, which is quite brilliant!
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
