frankf wrote:Not the Event Inputs. I'm not familiar with this. How does hat help? Your previous very specific post re multiple instances is interesting. I'm going to give it a try. How many cores does your MacPro have? Did you change any of the DP audio engine settings such as Work Priority? Sorry for all the questions.
I'm on a 2.66 12-core with 32GB, buffer is 512, Host Buffer Multiplier =1, and Work Priority "High".
The Event Inputs are what let's you get more than 16 MIDI outs from a single instance of VE Pro. I'm assuming you already understand the audio routing so I'll just explain the MIDI. Try this:
1. Launch VE Pro Server and create an instance with 3 V.I.'s. For instance 2 K5, and 1 Omnisphere. For demo purposes let's load up 16 LASS Vlns in the 1st K5, 16 LASS Vlas in the 2nd K5, and a some synthy low strings in Omnisphere. You'll see why later. It would be a good idea to name the instance at this point too. LEt's call it "STRINGS".
2. At the top of the V.I.'s channels set the first K5's MIDI port to "1", the second K5's MIDI port to "2", and the Omnisphere to MIDI port "3". All their MIDI channels (also at the top of the strip) should be set to "Omni".
3. In DP create a VE Pro instrument and connect it to the server instance "STRINGS" you just made. This part is probably what you're familiar with, and from here would go on to create MIDI tracks in DP and assign to this, but don't. Here's where it gets different.
4. Also in DP, create a Vienna Pro Event Input. Also assign it to the VE Pro Server instance "STRINGS" and make sure the MIDI INPUT is set to "1". Name this Event Input strip "LASS Vlns".
5. Create another Vienna Pro Event Input. Also assign it to the VE Pro Server instance "STRINGS" and make sure the MIDI INPUT is set to "2". Name this Event Input strip "LASS Vlas".
Create another Vienna Pro Event Input. Also assign it to the VE Pro Server instance "STRINGS" and make sure the MIDI INPUT is set to "3". Name this Event Input strip "OMNI".
6. NOW create your MIDI tracks in DP, and assign them to the "LASS Vlns", LASS Vlas", and OMNI as if they were 3 separate instances with 16 MIDI channels each.
I find that for my setup, a combination of each section of LASS using it's own instance in VE Pro (so no Event Inputs there), and most of the others on 1 instance (using Event Inputs) works best for me. Of course, that's the beauty of VE Pro - it's flexible.
I hope this helps.
