MOTU 896HD Christmas Lights
qnpqnp
Post by qnpqnp »
Hello,
I am sitting here with a broken MOTU 896HD first generation. It has a vague smell of burnt circuits and when I turn it on all LEDs starts flashing directly and don't ever stop. Even if I only plug in the power chord. No computer recon the card and I have not been tempering with the drivers or anything I like that. This happened just before a gig (god bless my replacement 828) at a venue with somewhat fluctuating power, microphones was electrified and so on. I have also a suspicion that someone in stage crew plugged in the firewire upside down because the FWport looks somewhat raped. I called MOTU and they friendly told me to buy a new card since the warranty was way over due. I googled the net and found tons of people with the same problem but none of the threads offered a solution, I also found a bunch of cards sold for parts on ebay with the same symptom.
Should I scavage it for the neutrik XLR ports and pots and put the rest in the junk or are there still hope for this poor unicorn?
Looking forward to any answer, ranting of poor venues and/or facepalm stagecrews ;-)
Best
Tom :unicorn:
qnpqnp
Re: MOTU 896HD Christmas Lights
Post by qnpqnp »
or maybe I could turn it into a birds nest and put it in the garden
qnpqnp
Post by qnpqnp »
or maybe as a breadbox?
no seriously, no one have any clue?
Todzilla
Post by Todzilla »
Similar thing happened to me after two years of problem free usage. Then after a whole weekend of this behavior, just as I was ready to ship it off, the problem stopped. That was five years ago, no trouble since.
Not sure how this relates to your issue, but thought I'd share.
-Todzilla
Huge sound generation & capture facilities
On the banks of the River Eno
__________________________________________________
DP 8!!!, OSX 10.7.3, 15" MacBook Pro w 16G RAM 256G SSD & 630GHD, MOTU 896HD, MX4, Komplete 8, Apogee Symphony I/O, Neumann U-89, pair of Peluso P12s, Seventh Circle & Demeter preamps, Lava lamp, stuffed frog playing bongos
Can you ship to MOTU for repair? I think they charge a flat $100 for 828 repairs (when they really just exchange with another used unit.)
allemande
Post by allemande »
It sounds like you accidentally plugged in the FireWire cable upside down. I once did the same thing with the same results. Motu will repair the unit for $100.
Good luck.
STUDIO 330•ALLEMANDE MUSIC
MOTU 7.24 on Mac Pro Quad core
Cranesong Hedd 192, 2408Mk3 (2),192 HD, 896MK3&896,
Avalon 737, Mindprint, DBX 580, 530, SSL VHD, Lindell 6X-500, Neve 542, TK Audio 501&500, dbx 160sl, 166, 163, 160, Tascam 4800, Geithain 903 monitors, etc.
brianrey
Post by brianrey »
Any set should be unplugged before repairing. If a set has no transformer, it is not line isolated. The small matchbox-sized electronic controllers do not have transformers in them, and sets with such controllers are also not line isolated, as well as all parts inside the controllers.
The number of strands of continuous light sets that may be safely daisy-chained in sequence varies based on whether the lights are LEDs, ordinary miniature light bulbs, or the larger C7/C9 type light bulbs. Other factors include the voltage of the set and the size of the wiring in the set. Those with questions should consult the manufacturer's instructions or an electrician.
[url]http://store.christmasdesigners.com/LED ... ringers/C9 LED Christmas lights
brianrey wrote:Any set should be unplugged before repairing. If a set has no transformer, it is not line isolated. The small matchbox-sized electronic controllers do not have transformers in them, and sets with such controllers are also not line isolated, as well as all parts inside the controllers.
Phil O
Post by Phil O »
Christmas lights, Shoosh. He's talkin about real Christmas lights. :shock: [cue Twilight Zone theme]
Phil O
Post by Phil O »
qnpqnp wrote:I called MOTU and they friendly told me to buy a new card since the warranty was way over due.
By "new card" do you mean a replacement board for the unit? Or is that the PCI board? Or are they saying to replace the whole device? (I guess I don't know much about the original 896) I would ask what it would cost for repairs and base my decision on cost of repair vs replace. Regarding scavenging for parts - I'm such a hopeless squirrel that my basement is a disaster area. Learn from my mistakes. If you decide not to repair it, chuck it. :roll:
kgdrum
Post by kgdrum »
I'd have to agree on not repairing the 896 & getting a new replacement unit.
The burnt smell might be blown capacitors & could really be a very complicated repair.
I had the original 896(my 1st I/O)
It's been improved on by many companies including MOTU and IMO to put more $$ into it would be an exercise in futility.
The repair cost now 11+ years later is probably more than its worth & unfortunately there might be other unforeseen issues with the unit by now.
stevenwright
Post by stevenwright »
It is not wise to get them repair because it will charge you high.You can better buy new set of LED lights at affordable price.
http://store.christmasdesigners.com/LED ... Stringers/
Phil O
Post by Phil O »
This is getting creepy.
kgdrum
Post by kgdrum »
getting?
jingle bells! ;-)
